[mapserver-commits] [mapserver/mapserver] c49a14: msGDALCleanup(): call GDALDestroy() with GDAL >= 2.4
Even Rouault
noreply at github.com
Fri Sep 13 08:16:30 PDT 2019
Branch: refs/heads/branch-7-4
Home: https://github.com/mapserver/mapserver
Commit: c49a14d16b37c6509fc4a0a4b8cfc74899f69d4e
https://github.com/mapserver/mapserver/commit/c49a14d16b37c6509fc4a0a4b8cfc74899f69d4e
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2019-09-12 (Thu, 12 Sep 2019)
Changed paths:
M mapgdal.c
Log Message:
Commit: d7b11f3adb3cf44035d09124300fdd7162a184a2
https://github.com/mapserver/mapserver/commit/d7b11f3adb3cf44035d09124300fdd7162a184a2
Changed paths:
M mapcopy.c
M mapfile.c
M maplabel.c
M maplayer.c
M mapmetadata.c
M mapogcsld.c
M mapogcsld.h
M mapogcsos.c
M mapogroutput.c
M mapows.c
M mapquery.c
M mapresample.c
M mapsymbol.c
M mapwcs.c
M mapwcs20.c
M mapwfs.c
M mapwms.c
M mapwmslayer.c
Log Message:
Fix various memory leaks found when running msautotest
Commit: 9d8ce59bbdb409e61b067b152f21a59f8a7d6f7a
https://github.com/mapserver/mapserver/commit/9d8ce59bbdb409e61b067b152f21a59f8a7d6f7a
Changed paths:
M mapgdal.c
M mapogr.cpp
M maputil.c
Log Message:
Free all GDAL and OGR resources when both are used
Commit: 5f505e0078eaffdd71f068ac18eeac8eddb60b5d
https://github.com/mapserver/mapserver/commit/5f505e0078eaffdd71f068ac18eeac8eddb60b5d
Changed paths:
M mapparser.c
M mapparser.h
M mapparser.y
Log Message:
Expression parser: fix memory leak on tostring() function
Commit: dee9685cb4ab981168b271b3f87df8324a9d98c7
https://github.com/mapserver/mapserver/commit/dee9685cb4ab981168b271b3f87df8324a9d98c7
Changed paths:
M msautotest/wxs/expected/wfsogr10_gpx.xml
M msautotest/wxs/wfs_ogr.map
Log Message:
Avoid triggering memory leak in GPX driver (now fixed in GDAL per https://github.com/OSGeo/gdal/commit/6c20fa95d33fd0452329067f766b2d71a5ebd87f)
Commit: 007dd562a6936fbc37754703ce8c1f023e85123b
https://github.com/mapserver/mapserver/commit/007dd562a6936fbc37754703ce8c1f023e85123b
Changed paths:
M msautotest/wxs/expected/wcs_20_getcov_gtiff_compress_deflate_predictor.tif
M msautotest/wxs/wcs_simple.map
Log Message:
wcs_20_getcov_gtiff_compress_deflate_predictor.tif test: switch to PREDICTOR=Horizontal, which is more appropriate here anyway, to avoid memleak with some GDAL versions
Commit: fe046204c56042f701a0eb6798e9611140a1b646
https://github.com/mapserver/mapserver/commit/fe046204c56042f701a0eb6798e9611140a1b646
Changed paths:
M .travis.yml
A ci/travis/after_success.sh
A ci/travis/before_install.sh
A ci/travis/script.sh
Log Message:
.travis.yml: move before_install, script and after_success sections to their own scripts
Commit: 22e120eb697afc68c5a5760c39ecefa8e99b58e4
https://github.com/mapserver/mapserver/commit/22e120eb697afc68c5a5760c39ecefa8e99b58e4
Changed paths:
M .travis.yml
M Makefile
M ci/travis/after_success.sh
M ci/travis/script.sh
M msautotest/pymod/mstestlib.py
M print-test-results.sh
Log Message:
.travis.yml: run PHP 7.2 target under -fsanitize=memory
Commit: 9762bb8dd8c4407ff6ba1c2ae276969bfe4ab4c6
https://github.com/mapserver/mapserver/commit/9762bb8dd8c4407ff6ba1c2ae276969bfe4ab4c6
Date: 2019-09-13 (Fri, 13 Sep 2019)
Changed paths:
M .travis.yml
M Makefile
M mapcopy.c
M mapfile.c
M mapgdal.c
M maplabel.c
M maplayer.c
M mapmetadata.c
M mapogcsld.c
M mapogcsld.h
M mapogcsos.c
M mapogr.cpp
M mapogroutput.c
M mapows.c
M mapparser.c
M mapparser.h
M mapparser.y
M mapquery.c
M mapresample.c
M mapsymbol.c
M maputil.c
M mapwcs.c
M mapwcs20.c
M mapwfs.c
M mapwms.c
M mapwmslayer.c
Log Message:
Merge pull request #5868 from rouault/memleak_fixes_7_4
Backport of memory leak fixes
Compare: https://github.com/mapserver/mapserver/compare/e08300429b4c...9762bb8dd8c4
More information about the mapserver-commits
