[mapserver-commits] [mapserver/mapserver] c2dab3: Sibling of 4c59b22c5a515065433ca071ff2b11b5126975a...
Even Rouault
noreply at github.com
Mon Sep 30 13:56:20 PDT 2019
Branch: refs/heads/cherry-pick-backport-5884-to-branch-7-4-89fc375a-7415-433e-93fb-a840a9ebe0e9
Home: https://github.com/mapserver/mapserver
Commit: c2dab38e380c7faee6d6e43ead2feaf3bb5c00a8
https://github.com/mapserver/mapserver/commit/c2dab38e380c7faee6d6e43ead2feaf3bb5c00a8
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2019-09-30 (Mon, 30 Sep 2019)
Changed paths:
M CMakeLists.txt
M HISTORY.TXT
M Makefile
M appveyor.yml
M create_mapaxisorder_csv.py
M fontcache.c
M mapaxisorder.csv
M mapaxisorder.h
M mapcairo.c
M mapcontext.c
M mapcopy.c
M mapfile.c
M mapgdal.c
M mapgeos.c
M mapimageio.c
M maplayer.c
M mapmetadata.c
M mapogcsld.c
M mapogcsld.h
M mapogcsos.c
M mapogroutput.c
M mapoutput.c
M mapows.h
M mappostgis.c
M mapproject.c
M mapscale.c
M mapscript/php/mapscript_i.c
M mapscript/php/php_mapscript.c
M mapscript/php/php_mapscript.h
M mapscript/python/pyextend.i
M mapscript/python/pymodule.i
M mapscript/python/tests/cases/map_test.py
M mapscript/swiginc/layer.i
M mapscript/swiginc/map.i
M mapserver.h
M mapstring.c
M mapthread.c
M maputil.c
M mapwfs.c
M msautotest/.gitignore
M msautotest/gdal/expected/tileindexmixedsrs.png
M msautotest/gdal/expected/tileindexmixedsrs2.png
M msautotest/gdal/expected/tileindexmixedsrs3.png
M msautotest/gdal/expected/tileindexmixedsrs4.png
M msautotest/gdal/tileindexmixedsrs.map
M msautotest/gdal/tileindexmixedsrs2.map
M msautotest/gdal/tileindexmixedsrs3.map
M msautotest/gdal/tileindexmixedsrs4.map
R msautotest/sld/arithmetic_line.map
R msautotest/sld/arithmetic_point.map
R msautotest/sld/arithmetic_polygon.map
R msautotest/sld/arithmetic_text.map
R msautotest/sld/base.map
R msautotest/sld/data/fonts.lst
R msautotest/sld/data/hexagon.dbf
R msautotest/sld/data/hexagon.json
R msautotest/sld/data/hexagon.prj
R msautotest/sld/data/hexagon.shp
R msautotest/sld/data/hexagon.shx
R msautotest/sld/data/inner.dbf
R msautotest/sld/data/inner.json
R msautotest/sld/data/inner.prj
R msautotest/sld/data/inner.shp
R msautotest/sld/data/inner.shx
R msautotest/sld/data/plot.dbf
R msautotest/sld/data/plot.json
R msautotest/sld/data/plot.prj
R msautotest/sld/data/plot.shp
R msautotest/sld/data/plot.shx
R msautotest/sld/data/set.json
R msautotest/sld/expected/base_mapfile.png
R msautotest/sld/expected/base_sldbody.png
R msautotest/sld/expected/map_reference.png
R msautotest/sld/expected/size_mapfile.png
R msautotest/sld/expected/size_sldbody.png
R msautotest/sld/expected/sld_line_expression_strokeopacity.png
R msautotest/sld/expected/sld_line_expression_strokewidth.png
R msautotest/sld/expected/sld_line_literal_stroke.png
R msautotest/sld/expected/sld_line_literal_strokeopacity.png
R msautotest/sld/expected/sld_line_literal_strokewidth.png
R msautotest/sld/expected/sld_line_propertyname_stroke.png
R msautotest/sld/expected/sld_line_propertyname_strokeopacity.png
R msautotest/sld/expected/sld_line_propertyname_strokewidth.png
R msautotest/sld/expected/sld_point_expression_displacementx.png
R msautotest/sld/expected/sld_point_expression_displacementy.png
R msautotest/sld/expected/sld_point_expression_opacity.png
R msautotest/sld/expected/sld_point_expression_rotation.png
R msautotest/sld/expected/sld_point_expression_size.png
R msautotest/sld/expected/sld_point_expression_strokewidth.png
R msautotest/sld/expected/sld_point_literal_displacementx.png
R msautotest/sld/expected/sld_point_literal_displacementy.png
R msautotest/sld/expected/sld_point_literal_fill.png
R msautotest/sld/expected/sld_point_literal_opacity.png
R msautotest/sld/expected/sld_point_literal_rotation.png
R msautotest/sld/expected/sld_point_literal_size.png
R msautotest/sld/expected/sld_point_literal_stroke.png
R msautotest/sld/expected/sld_point_literal_strokewidth.png
R msautotest/sld/expected/sld_point_propertyname_displacementx.png
R msautotest/sld/expected/sld_point_propertyname_displacementy.png
R msautotest/sld/expected/sld_point_propertyname_fill.png
R msautotest/sld/expected/sld_point_propertyname_opacity.png
R msautotest/sld/expected/sld_point_propertyname_rotation.png
R msautotest/sld/expected/sld_point_propertyname_size.png
R msautotest/sld/expected/sld_point_propertyname_stroke.png
R msautotest/sld/expected/sld_point_propertyname_strokewidth.png
R msautotest/sld/expected/sld_polygon_expression_fillopacity.png
R msautotest/sld/expected/sld_polygon_expression_strokeopacity.png
R msautotest/sld/expected/sld_polygon_expression_strokewidth.png
R msautotest/sld/expected/sld_polygon_literal_fill.png
R msautotest/sld/expected/sld_polygon_literal_fillopacity.png
R msautotest/sld/expected/sld_polygon_literal_stroke.png
R msautotest/sld/expected/sld_polygon_literal_strokeopacity.png
R msautotest/sld/expected/sld_polygon_literal_strokewidth.png
R msautotest/sld/expected/sld_polygon_propertyname_fill.png
R msautotest/sld/expected/sld_polygon_propertyname_fillopacity.png
R msautotest/sld/expected/sld_polygon_propertyname_stroke.png
R msautotest/sld/expected/sld_polygon_propertyname_strokeopacity.png
R msautotest/sld/expected/sld_polygon_propertyname_strokewidth.png
R msautotest/sld/expected/sld_reference.png
R msautotest/sld/expected/sld_text_expression_fontsize.png
R msautotest/sld/expected/sld_text_expression_rotation.png
R msautotest/sld/expected/sld_text_literal_fill.png
R msautotest/sld/expected/sld_text_literal_fontsize.png
R msautotest/sld/expected/sld_text_literal_halofill.png
R msautotest/sld/expected/sld_text_literal_rotation.png
R msautotest/sld/expected/sld_text_propertyname_fill.png
R msautotest/sld/expected/sld_text_propertyname_fontsize.png
R msautotest/sld/expected/sld_text_propertyname_halofill.png
R msautotest/sld/expected/sld_text_propertyname_rotation.png
R msautotest/sld/reference.map
R msautotest/sld/run_test.py
R msautotest/sld/size.map
M msautotest/valgrind-suppressions.txt
M msautotest/wxs/data/polar_stereo.tif
R msautotest/wxs/expected/wfsogr20_geojson.json
R msautotest/wxs/expected/wfsogr20_geojson_with_predefine_native_data.json
M msautotest/wxs/wfs_200.map
M msautotest/wxs/wfs_200_allgeoms.map
M msautotest/wxs/wfs_200_cite.map
M msautotest/wxs/wfs_200_cite_postgis.map
M msautotest/wxs/wfs_200_low_wfsmaxfeatures_no_compute_number_matched.map
M msautotest/wxs/wfs_filter.map
M msautotest/wxs/wfs_filter_ogr.map
M msautotest/wxs/wfs_filter_postgis.map
M msautotest/wxs/wfs_filter_projmeter.map
M msautotest/wxs/wfs_ogr_geojson.map
M msautotest/wxs/wfs_ogr_native_sql.map
M msautotest/wxs/wfs_ogr_no_native_sql.map
M msautotest/wxs/wfs_time.map
M msautotest/wxs/wfs_time_ogr.map
M msautotest/wxs/wfs_time_postgis.map
M msautotest/wxs/wms_inspire.map
M msautotest/wxs/wms_north_polar_stereo_extent.map
M msautotest/wxs/wms_raster.map
M msautotest/wxs/wms_uvraster_map_reprojection.map
M renderers/agg/include/agg_conv_curve.h
M renderers/agg/include/agg_path_storage.h
Log Message:
Sibling of 4c59b22c5a515065433ca071ff2b11b5126975a3 [skip ci]
skip-checks: true
More information about the mapserver-commits
