[mapserver-commits] [mapserver/mapserver] 9c45c3: Sibling of 5c5b7bdd364ff4a7408ac9a871e27857c0d9064...
ejn noreply at github.com
Mon Sep 30 13:58:49 PDT 2019
  Branch: refs/heads/cherry-pick-backport-5879-to-branch-7-4-a599c69f-dc95-488d-9121-336d0d5b3cfa
  Home:   https://github.com/mapserver/mapserver
  Commit: 9c45c3f3008fd96a5352b6e12283df01c7be6895
      https://github.com/mapserver/mapserver/commit/9c45c3f3008fd96a5352b6e12283df01c7be6895
  Author: Edward Nash <e.nash at dvz-mv.de>
  Date:   2019-09-24 (Tue, 24 Sep 2019)
  Changed paths:
    M CMakeLists.txt
    M HISTORY.TXT
    M Makefile
    M appveyor.yml
    M create_mapaxisorder_csv.py
    M mapaxisorder.csv
    M mapaxisorder.h
    M mapcairo.c
    M mapcontext.c
    M mapcopy.c
    M mapfile.c
    M mapgdal.c
    M mapimageio.c
    M maplayer.c
    M mapmetadata.c
    M mapogcsld.c
    M mapogcsld.h
    M mapogcsos.c
    M mapogroutput.c
    M mapoutput.c
    M mapows.h
    M mappostgis.c
    M mapproject.c
    M mapscale.c
    M mapscript/php/mapscript_i.c
    M mapscript/php/php_mapscript.c
    M mapscript/php/php_mapscript.h
    M mapscript/python/pyextend.i
    M mapscript/python/pymodule.i
    M mapscript/python/tests/cases/map_test.py
    M mapscript/swiginc/layer.i
    M mapscript/swiginc/map.i
    M mapserver.h
    M mapthread.c
    M maputil.c
    M mapwfs.c
    M msautotest/.gitignore
    M msautotest/gdal/expected/tileindexmixedsrs.png
    M msautotest/gdal/expected/tileindexmixedsrs2.png
    M msautotest/gdal/expected/tileindexmixedsrs3.png
    M msautotest/gdal/expected/tileindexmixedsrs4.png
    M msautotest/gdal/tileindexmixedsrs.map
    M msautotest/gdal/tileindexmixedsrs2.map
    M msautotest/gdal/tileindexmixedsrs3.map
    M msautotest/gdal/tileindexmixedsrs4.map
    R msautotest/sld/arithmetic_line.map
    R msautotest/sld/arithmetic_point.map
    R msautotest/sld/arithmetic_polygon.map
    R msautotest/sld/arithmetic_text.map
    R msautotest/sld/base.map
    R msautotest/sld/data/fonts.lst
    R msautotest/sld/data/hexagon.dbf
    R msautotest/sld/data/hexagon.json
    R msautotest/sld/data/hexagon.prj
    R msautotest/sld/data/hexagon.shp
    R msautotest/sld/data/hexagon.shx
    R msautotest/sld/data/inner.dbf
    R msautotest/sld/data/inner.json
    R msautotest/sld/data/inner.prj
    R msautotest/sld/data/inner.shp
    R msautotest/sld/data/inner.shx
    R msautotest/sld/data/plot.dbf
    R msautotest/sld/data/plot.json
    R msautotest/sld/data/plot.prj
    R msautotest/sld/data/plot.shp
    R msautotest/sld/data/plot.shx
    R msautotest/sld/data/set.json
    R msautotest/sld/expected/base_mapfile.png
    R msautotest/sld/expected/base_sldbody.png
    R msautotest/sld/expected/map_reference.png
    R msautotest/sld/expected/size_mapfile.png
    R msautotest/sld/expected/size_sldbody.png
    R msautotest/sld/expected/sld_line_expression_strokeopacity.png
    R msautotest/sld/expected/sld_line_expression_strokewidth.png
    R msautotest/sld/expected/sld_line_literal_stroke.png
    R msautotest/sld/expected/sld_line_literal_strokeopacity.png
    R msautotest/sld/expected/sld_line_literal_strokewidth.png
    R msautotest/sld/expected/sld_line_propertyname_stroke.png
    R msautotest/sld/expected/sld_line_propertyname_strokeopacity.png
    R msautotest/sld/expected/sld_line_propertyname_strokewidth.png
    R msautotest/sld/expected/sld_point_expression_displacementx.png
    R msautotest/sld/expected/sld_point_expression_displacementy.png
    R msautotest/sld/expected/sld_point_expression_opacity.png
    R msautotest/sld/expected/sld_point_expression_rotation.png
    R msautotest/sld/expected/sld_point_expression_size.png
    R msautotest/sld/expected/sld_point_expression_strokewidth.png
    R msautotest/sld/expected/sld_point_literal_displacementx.png
    R msautotest/sld/expected/sld_point_literal_displacementy.png
    R msautotest/sld/expected/sld_point_literal_fill.png
    R msautotest/sld/expected/sld_point_literal_opacity.png
    R msautotest/sld/expected/sld_point_literal_rotation.png
    R msautotest/sld/expected/sld_point_literal_size.png
    R msautotest/sld/expected/sld_point_literal_stroke.png
    R msautotest/sld/expected/sld_point_literal_strokewidth.png
    R msautotest/sld/expected/sld_point_propertyname_displacementx.png
    R msautotest/sld/expected/sld_point_propertyname_displacementy.png
    R msautotest/sld/expected/sld_point_propertyname_fill.png
    R msautotest/sld/expected/sld_point_propertyname_opacity.png
    R msautotest/sld/expected/sld_point_propertyname_rotation.png
    R msautotest/sld/expected/sld_point_propertyname_size.png
    R msautotest/sld/expected/sld_point_propertyname_stroke.png
    R msautotest/sld/expected/sld_point_propertyname_strokewidth.png
    R msautotest/sld/expected/sld_polygon_expression_fillopacity.png
    R msautotest/sld/expected/sld_polygon_expression_strokeopacity.png
    R msautotest/sld/expected/sld_polygon_expression_strokewidth.png
    R msautotest/sld/expected/sld_polygon_literal_fill.png
    R msautotest/sld/expected/sld_polygon_literal_fillopacity.png
    R msautotest/sld/expected/sld_polygon_literal_stroke.png
    R msautotest/sld/expected/sld_polygon_literal_strokeopacity.png
    R msautotest/sld/expected/sld_polygon_literal_strokewidth.png
    R msautotest/sld/expected/sld_polygon_propertyname_fill.png
    R msautotest/sld/expected/sld_polygon_propertyname_fillopacity.png
    R msautotest/sld/expected/sld_polygon_propertyname_stroke.png
    R msautotest/sld/expected/sld_polygon_propertyname_strokeopacity.png
    R msautotest/sld/expected/sld_polygon_propertyname_strokewidth.png
    R msautotest/sld/expected/sld_reference.png
    R msautotest/sld/expected/sld_text_expression_fontsize.png
    R msautotest/sld/expected/sld_text_expression_rotation.png
    R msautotest/sld/expected/sld_text_literal_fill.png
    R msautotest/sld/expected/sld_text_literal_fontsize.png
    R msautotest/sld/expected/sld_text_literal_halofill.png
    R msautotest/sld/expected/sld_text_literal_rotation.png
    R msautotest/sld/expected/sld_text_propertyname_fill.png
    R msautotest/sld/expected/sld_text_propertyname_fontsize.png
    R msautotest/sld/expected/sld_text_propertyname_halofill.png
    R msautotest/sld/expected/sld_text_propertyname_rotation.png
    R msautotest/sld/reference.map
    R msautotest/sld/run_test.py
    R msautotest/sld/size.map
    M msautotest/valgrind-suppressions.txt
    M msautotest/wxs/data/polar_stereo.tif
    R msautotest/wxs/expected/wfsogr20_geojson.json
    R msautotest/wxs/expected/wfsogr20_geojson_with_predefine_native_data.json
    M msautotest/wxs/wfs_200.map
    M msautotest/wxs/wfs_200_allgeoms.map
    M msautotest/wxs/wfs_200_cite.map
    M msautotest/wxs/wfs_200_cite_postgis.map
    M msautotest/wxs/wfs_200_low_wfsmaxfeatures_no_compute_number_matched.map
    M msautotest/wxs/wfs_filter.map
    M msautotest/wxs/wfs_filter_ogr.map
    M msautotest/wxs/wfs_filter_postgis.map
    M msautotest/wxs/wfs_filter_projmeter.map
    M msautotest/wxs/wfs_ogr_geojson.map
    M msautotest/wxs/wfs_ogr_native_sql.map
    M msautotest/wxs/wfs_ogr_no_native_sql.map
    M msautotest/wxs/wfs_time.map
    M msautotest/wxs/wfs_time_ogr.map
    M msautotest/wxs/wfs_time_postgis.map
    M msautotest/wxs/wms_inspire.map
    M msautotest/wxs/wms_north_polar_stereo_extent.map
    M msautotest/wxs/wms_raster.map
    M msautotest/wxs/wms_uvraster_map_reprojection.map
    M renderers/agg/include/agg_conv_curve.h
    M renderers/agg/include/agg_path_storage.h
  Log Message:
  Sibling of 5c5b7bdd364ff4a7408ac9a871e27857c0d9064d [skip ci]
skip-checks: true
