[mapserver-commits] [mapserver/mapserver] cb2f60: Test MSSQL with Appveyor (#2)
Even Rouault
noreply at github.com
Thu Feb 13 02:00:48 PST 2020
Branch: refs/heads/master
Home: https://github.com/mapserver/mapserver
Commit: cb2f603a93489f3c8e8dbea444148a9cfb28bdcc
https://github.com/mapserver/mapserver/commit/cb2f603a93489f3c8e8dbea444148a9cfb28bdcc
Author: Seth G <geographika at gmail.com>
Date: 2020-02-11 (Tue, 11 Feb 2020)
Changed paths:
M CMakeLists.txt
M appveyor.yml
M mapmssql2008.c
M mapscript/python/pymodule.i
M msautotest/misc/ogr_direct.map
M msautotest/mspython/test_rq.py
A msautotest/mssql/create_mssql_db.bat
A msautotest/mssql/expected/filters_mssql_test001.png
A msautotest/mssql/expected/filters_mssql_test002.png
A msautotest/mssql/expected/filters_mssql_test003.png
A msautotest/mssql/expected/filters_mssql_test004.png
A msautotest/mssql/expected/filters_mssql_test005.png
A msautotest/mssql/expected/filters_mssql_test006.png
A msautotest/mssql/expected/filters_mssql_test007.png
A msautotest/mssql/expected/filters_mssql_test008.png
A msautotest/mssql/expected/filters_mssql_test009.png
A msautotest/mssql/filters_mssql.map
A msautotest/mssql/include/bdry_counpy2_mssql.map
A msautotest/mssql/run_test.py
M msautotest/pymod/mstestlib.py
Log Message:
* Add MSSQL to CI
* Update db script and Python tests
* Turn off shallow_clone to clone msautotest
* Restrict clone size
* Add mssql test case and results
* Build MSSQL driver
* Remove include directory that breaks build
* Set projection and update results paths
* Use file protocol for pip
* Change test order
* Add MSSQL to CI
* Fix YAML issues with %
* Add full path to work on Windows
* Ignore test on Windows as it fails
* Update test and skip failing tests
* Fix some compiler warnings and disable the rest
Commit: 91ef9a6e26a52d37fc2481514332ce0928db3d86
https://github.com/mapserver/mapserver/commit/91ef9a6e26a52d37fc2481514332ce0928db3d86
Author: sethg <sethg at geographika.co.uk>
Changed paths:
M CMakeLists.txt
M mapmssql2008.c
M msautotest/mssql/create_mssql_db.bat
Log Message:
Clean up debug statements
Commit: dd90bae412442d715adff9256d621a0f910f61ac
https://github.com/mapserver/mapserver/commit/dd90bae412442d715adff9256d621a0f910f61ac
Changed paths:
M CMakeLists.txt
M mapmssql2008.c
Log Message:
Fix compiler warnings in mapmssql2008.c
Commit: f64d1ab6b31b706876e79efb10f657950f283fde
https://github.com/mapserver/mapserver/commit/f64d1ab6b31b706876e79efb10f657950f283fde
Changed paths:
M mapmssql2008.c
Log Message:
Use MS_FALSE and MS_TRUE
Commit: 28b9f8395b005c9cdd307cf5a81ca50de29c3474
https://github.com/mapserver/mapserver/commit/28b9f8395b005c9cdd307cf5a81ca50de29c3474
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2020-02-13 (Thu, 13 Feb 2020)
Changed paths:
M CMakeLists.txt
M appveyor.yml
M mapmssql2008.c
Log Message:
Merge pull request #5990 from geographika/mssql-msautotest
Build and run tests for the MSSQL Driver on Appveyor
Compare: https://github.com/mapserver/mapserver/compare/cb7a9fc8c9df...28b9f8395b00
More information about the mapserver-commits
