[mapserver-commits] [MapServer/MapServer] 7dfe7e: Raster drawing: use the GDAL mask band when availa...
Even Rouault noreply at github.com
Mon Oct 12 12:46:43 PDT 2020
  Branch: refs/heads/master
  Home:   https://github.com/MapServer/MapServer
  Commit: 7dfe7e17c13096694420f4437b662306d74cdaac
      https://github.com/MapServer/MapServer/commit/7dfe7e17c13096694420f4437b662306d74cdaac
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2020-10-06 (Tue, 06 Oct 2020)
  Changed paths:
    M mapdrawgdal.c
    M msautotest/gdal/unclassified.map
    M msautotest/renderers/compositing.map
    M msautotest/renderers/raster_simple.map
    M msautotest/renderers/raster_simple_opacity.map
  Log Message:
  Raster drawing: use the GDAL mask band when available, even if PROCESSING BANDS=xxx is used (unless PROCESSING USE_MASK_BAND=NO is set)
  Commit: 1a0602ae5991bd5e0563b910bbb8569443624f66
      https://github.com/MapServer/MapServer/commit/1a0602ae5991bd5e0563b910bbb8569443624f66
  Date:   2020-10-12 (Mon, 12 Oct 2020)
  Changed paths:
    M mapdrawgdal.c
  Log Message:
  Merge pull request #6165 from rouault/drawgdal_bands_mask_band
Compare: https://github.com/MapServer/MapServer/compare/3b02dddcf9a3...1a0602ae5991
