[mapserver-commits] [MapServer/MapServer] 4fd204: Fix Coverity Scan false positive about freeing map...
Jeff McKenna
noreply at github.com
Mon Apr 26 08:24:31 PDT 2021
Branch: refs/heads/main
Home: https://github.com/MapServer/MapServer
Commit: 4fd204bcdfb25cff3d858777255c2147cfe7e5ce
https://github.com/MapServer/MapServer/commit/4fd204bcdfb25cff3d858777255c2147cfe7e5ce
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2021-04-24 (Sat, 24 Apr 2021)
Changed paths:
M maplabel.c
M maplegend.c
M mapserver.h
Log Message:
Fix Coverity Scan false positive about freeing map->legend.label (CID 1503451, 1503355)
Commit: a48e5a4478208879d67ff9fedba26d28185d7466
https://github.com/MapServer/MapServer/commit/a48e5a4478208879d67ff9fedba26d28185d7466
Changed paths:
M mapserver.h
Log Message:
Add IGNORE_RET_VAL() inline function
Commit: 94f3db38888884759192e4dd54943bce0a6a1a11
https://github.com/MapServer/MapServer/commit/94f3db38888884759192e4dd54943bce0a6a1a11
Changed paths:
M mapwms.cpp
Log Message:
Explicitly ignore return value (CID 1503593)
Commit: d93612635a8c2674f7f9342eaee1a4d0d25a1918
https://github.com/MapServer/MapServer/commit/d93612635a8c2674f7f9342eaee1a4d0d25a1918
Changed paths:
M mapshape.c
Log Message:
Explicitly ignore return value (CID 1503578)
Commit: 8dc41040c30a2df2583d80a2fbe4e74166fab4c9
https://github.com/MapServer/MapServer/commit/8dc41040c30a2df2583d80a2fbe4e74166fab4c9
Changed paths:
M mapshape.c
Log Message:
msSHPReadAllocateBuffer(): use correct realloc() pattern and validate size (CID 1503560)
Commit: 94632e1de92e4eab2c91aeda7b05a78724e3ee38
https://github.com/MapServer/MapServer/commit/94632e1de92e4eab2c91aeda7b05a78724e3ee38
Changed paths:
M mapuvraster.c
Log Message:
uvraster: remove useless ceil() (CID 1503549)
Commit: 70295d6d49e6d2d6204084a5874d274d27de5726
https://github.com/MapServer/MapServer/commit/70295d6d49e6d2d6204084a5874d274d27de5726
Changed paths:
M renderers/agg/src/agg_font_freetype.cpp
Log Message:
agg_font_freetype.cpp: fix incorrect use of memcpy() (CID 1503528)
Commit: 3c0b423941e5ce452f4834cc3027f12397c86f60
https://github.com/MapServer/MapServer/commit/3c0b423941e5ce452f4834cc3027f12397c86f60
Changed paths:
M mapwms.cpp
Log Message:
msWMSApplyFilter(): add assertions to avoid false positive warning about nullptr dereference (CID 1503489)
Commit: cbf0f8dfee26d2961a5a1863c0a733b6b4dc8b24
https://github.com/MapServer/MapServer/commit/cbf0f8dfee26d2961a5a1863c0a733b6b4dc8b24
Changed paths:
M mapogcsld.c
Log Message:
msSLDParseOgcExpression(): make it obvious that no nullptr dereferencing will occur (CID 1503465)
Commit: 2477200ad38c2f125cbb9d8f932d5e9cd7abccfa
https://github.com/MapServer/MapServer/commit/2477200ad38c2f125cbb9d8f932d5e9cd7abccfa
Changed paths:
M mapwmslayer.c
Log Message:
msPrepareWMSLayerRequest(): avoid false positive warning about nullptr dereference (CID 1503462)
Commit: 6d0c6a44a5218e8febdbc3fcba291e202d40b891
https://github.com/MapServer/MapServer/commit/6d0c6a44a5218e8febdbc3fcba291e202d40b891
Changed paths:
M mapwfs.cpp
Log Message:
msWFSWriteGeometryElement(): remove useless nullptr check (CID 1503443)
Commit: 74b8a7ca5ef0fb9274cf7468558756b393ab7474
https://github.com/MapServer/MapServer/commit/74b8a7ca5ef0fb9274cf7468558756b393ab7474
Changed paths:
M maptemplate.c
Log Message:
maptemplate.c: add assert() to avoid warning about nullptr deref (CID 1503429)
Commit: ad91457e98d7a403279416b6d594ac00d5c8b540
https://github.com/MapServer/MapServer/commit/ad91457e98d7a403279416b6d594ac00d5c8b540
Changed paths:
M mapwcs20.cpp
Log Message:
msWCSGetCoverage20(): remove dead branch (CID 1503406)
Commit: e306cd034fa4d7b2c9e60d5ecb923e8693025e77
https://github.com/MapServer/MapServer/commit/e306cd034fa4d7b2c9e60d5ecb923e8693025e77
Author: Jeff McKenna <jmckenna at gatewaygeomatics.com>
Date: 2021-04-26 (Mon, 26 Apr 2021)
Changed paths:
M maplabel.c
M maplegend.c
M mapogcsld.c
M mapserver.h
M mapshape.c
M maptemplate.c
M mapuvraster.c
M mapwcs20.cpp
M mapwfs.cpp
M mapwms.cpp
M mapwmslayer.c
Log Message:
Merge pull request #6311 from rouault/coverity_scan_fixes
Another batch of coverity scan fixes
Compare: https://github.com/MapServer/MapServer/compare/e296cb15e9df...e306cd034fa4
More information about the mapserver-commits
