[mapserver-commits] [MapServer/MapServer] d7faf8: test check-crlf again
Seth G
noreply at github.com
Fri Jan 15 13:41:37 PST 2021
Branch: refs/heads/main
Home: https://github.com/MapServer/MapServer
Commit: d7faf8ac85e8b5388d803faed2cd733bc907608b
https://github.com/MapServer/MapServer/commit/d7faf8ac85e8b5388d803faed2cd733bc907608b
Author: jmckenna <jmckenna at gatewaygeomatics.com>
Date: 2020-10-01 (Thu, 01 Oct 2020)
Changed paths:
A .github/workflows/check-crlf.yml
Log Message:
Commit: 0ad217c6f5d8eb33e5281e8f4b7a161d68eba408
https://github.com/MapServer/MapServer/commit/0ad217c6f5d8eb33e5281e8f4b7a161d68eba408
Changed paths:
M .github/workflows/check-crlf.yml
Log Message:
try to exclude dirs
Commit: e63dc2a99a080f20fce74c7a2d3b24b5d8e70595
https://github.com/MapServer/MapServer/commit/e63dc2a99a080f20fce74c7a2d3b24b5d8e70595
Date: 2020-10-02 (Fri, 02 Oct 2020)
Changed paths:
Log Message:
upgrade to 1.1.0 tag
Commit: df4f72028e28a38759e294380637dee6edde5e2c
https://github.com/MapServer/MapServer/commit/df4f72028e28a38759e294380637dee6edde5e2c
Changed paths:
Log Message:
change config
Commit: 44d13422218b3ef2857d2d9f4e49a106dd858c00
https://github.com/MapServer/MapServer/commit/44d13422218b3ef2857d2d9f4e49a106dd858c00
Changed paths:
Log Message:
upgrade to 1.1.1 tag
Commit: f38cb93857995fdb23333aeec1065ad0d8f12e7c
https://github.com/MapServer/MapServer/commit/f38cb93857995fdb23333aeec1065ad0d8f12e7c
Changed paths:
Log Message:
change config
Commit: adb5d9e5fa3dca2e3f43afd59d18d3d2dfa79992
https://github.com/MapServer/MapServer/commit/adb5d9e5fa3dca2e3f43afd59d18d3d2dfa79992
Changed paths:
Log Message:
change config
Commit: 9636a5dfe4a6a0651048224883a935612ee88d08
https://github.com/MapServer/MapServer/commit/9636a5dfe4a6a0651048224883a935612ee88d08
Changed paths:
Log Message:
fallback to 1.0.0 tag
Commit: 9f189731efd913fab6a11434ec6fa213297fcf42
https://github.com/MapServer/MapServer/commit/9f189731efd913fab6a11434ec6fa213297fcf42
Changed paths:
Log Message:
bump to 1.1.1 tag
Commit: deee15184e9dc768f36504927864ad5aeebda4d3
https://github.com/MapServer/MapServer/commit/deee15184e9dc768f36504927864ad5aeebda4d3
Date: 2020-10-04 (Sun, 04 Oct 2020)
Changed paths:
M fontcache.c
M mapproject.c
M mapwmslayer.c
Log Message:
Merge branch 'master' of github.com:MapServer/MapServer into check-crlf
Commit: 1def0e9ee040f27d69d07b3d6d0cbf8dead9f0ab
https://github.com/MapServer/MapServer/commit/1def0e9ee040f27d69d07b3d6d0cbf8dead9f0ab
Changed paths:
Log Message:
bump tag version
Commit: 71e5576453592855bd68d758f1c3d98f9b7347dd
https://github.com/MapServer/MapServer/commit/71e5576453592855bd68d758f1c3d98f9b7347dd
Author: Jeff McKenna <jmckenna at gatewaygeomatics.com>
Changed paths:
Log Message:
Merge pull request #6159 from jmckenna/check-crlf
Enable check-crlf github action
Commit: 738c8f029aa4d9e7a21858476cc55ea43c92c383
https://github.com/MapServer/MapServer/commit/738c8f029aa4d9e7a21858476cc55ea43c92c383
Changed paths:
M mapscript/csharp/Makefile.vc
Log Message:
Merge pull request #6158 from szekerest/csharp-test-fix
Remove reference to the missing nmake.opt
Commit: 42bd44cbee2ad17ad3d9343c178b595a40857d36
https://github.com/MapServer/MapServer/commit/42bd44cbee2ad17ad3d9343c178b595a40857d36
Author: Even Rouault <even.rouault at spatialys.com>
Changed paths:
M CMakeLists.txt
Log Message:
CMakeLists.txt: remove obsolete comments in option description now that GDAL and PROJ are required
Commit: b70464ee185542df1cd3235bc5575afe47ffb73c
https://github.com/MapServer/MapServer/commit/b70464ee185542df1cd3235bc5575afe47ffb73c
Changed paths:
M mapgml.c
M mapogcfilter.cpp
M mapogcfiltercommon.cpp
M mapogcsld.c
M mapows.c
M mapows.h
Log Message:
Fix build with WITH_SOS/WFS/WCS/WMS/CLIENT_WMS/CLIENT_WFS=OFF
Commit: ebe3fddb8e171255876952e09bd9e6241dff4bfb
https://github.com/MapServer/MapServer/commit/ebe3fddb8e171255876952e09bd9e6241dff4bfb
Changed paths:
M mapgml.c
M mapogcfilter.cpp
M mapogcsld.c
M mapows.c
M mapows.h
Log Message:
Merge pull request #6162 from rouault/fix_build_without_sos_wxs
Commit: c3b23bb584f32f18a2ebbde62d58861560de946e
https://github.com/MapServer/MapServer/commit/c3b23bb584f32f18a2ebbde62d58861560de946e
Changed paths:
M mapmssql2008.c
Log Message:
mapmssql2008.c: fix warnings when building on Linux
wchar_t is a 4-byte int whereas SQLWCHAR is a 2-byte int...
Commit: d214d3c85bf8dea0b2f50cd6f3237b33d38f3726
https://github.com/MapServer/MapServer/commit/d214d3c85bf8dea0b2f50cd6f3237b33d38f3726
Date: 2020-10-05 (Mon, 05 Oct 2020)
Changed paths:
M mapmssql2008.c
Log Message:
Merge pull request #6163 from rouault/mssql2008_warning_fixes
Commit: 0fb66a3589c8be7802854696f25485863b3acc39
https://github.com/MapServer/MapServer/commit/0fb66a3589c8be7802854696f25485863b3acc39
Author: jbo-ads <jbo-ads at mailo.com>
Changed paths:
M scripts/vagrant/packages.sh
Log Message:
Add Kitware's APT repository to get recent CMake in Vagrant build
Commit: 3b02dddcf9a3b4fd0b73db2c749fa8231d9fa01c
https://github.com/MapServer/MapServer/commit/3b02dddcf9a3b4fd0b73db2c749fa8231d9fa01c
Changed paths:
Log Message:
Merge pull request #6164 from jbo-ads/vagrant-build-python
Commit: 7dfe7e17c13096694420f4437b662306d74cdaac
https://github.com/MapServer/MapServer/commit/7dfe7e17c13096694420f4437b662306d74cdaac
Date: 2020-10-06 (Tue, 06 Oct 2020)
Changed paths:
M mapdrawgdal.c
M msautotest/gdal/unclassified.map
M msautotest/renderers/compositing.map
M msautotest/renderers/raster_simple.map
M msautotest/renderers/raster_simple_opacity.map
Log Message:
Raster drawing: use the GDAL mask band when available, even if PROCESSING BANDS=xxx is used (unless PROCESSING USE_MASK_BAND=NO is set)
Commit: 1a0602ae5991bd5e0563b910bbb8569443624f66
https://github.com/MapServer/MapServer/commit/1a0602ae5991bd5e0563b910bbb8569443624f66
Date: 2020-10-12 (Mon, 12 Oct 2020)
Changed paths:
M mapdrawgdal.c
Log Message:
Merge pull request #6165 from rouault/drawgdal_bands_mask_band
Commit: d3195951873193512e8baa86d1c6cd0b15bc04e0
https://github.com/MapServer/MapServer/commit/d3195951873193512e8baa86d1c6cd0b15bc04e0
Author: Tom Kralidis <tomkralidis at gmail.com>
Changed paths:
M mapmetadata.c
M msautotest/wxs/expected/ows_metadata_layer_vector.xml
M msautotest/wxs/expected/ows_metadata_wms_capabilities111.xml
M msautotest/wxs/expected/ows_metadata_wms_capabilities130.xml
M msautotest/wxs/ows_metadata.map
Log Message:
Metadata: use attribution_title if available (#6166)
Commit: c0d2b75141a0017b529fbcf4935e0887adda5543
https://github.com/MapServer/MapServer/commit/c0d2b75141a0017b529fbcf4935e0887adda5543
Changed paths:
M mapmetadata.c
M msautotest/wxs/expected/ows_metadata_layer_raster.xml
Log Message:
Metadata: remove unused function and erroneous default date output
Commit: 5e49adc2e9dbe660575af380df3c281b62e8e381
https://github.com/MapServer/MapServer/commit/5e49adc2e9dbe660575af380df3c281b62e8e381
Date: 2020-10-13 (Tue, 13 Oct 2020)
Changed paths:
M mapmetadata.c
Log Message:
Merge pull request #6169 from tomkralidis/issue-6166
Commit: 2502fb36cb2910ace329584bebf0f8339fb35ff9
https://github.com/MapServer/MapServer/commit/2502fb36cb2910ace329584bebf0f8339fb35ff9
Author: Thomas Bonfort <thomas.bonfort at gmail.com>
Changed paths:
M .travis.yml
Log Message:
remove myself from travis notifications
Commit: 4a5bc7c2c6f84b499161d4184f7aa2b2cb5b3224
https://github.com/MapServer/MapServer/commit/4a5bc7c2c6f84b499161d4184f7aa2b2cb5b3224
Changed paths:
M mapwfs11.cpp
Log Message:
WFS 1.1/2.0: do not write empty ows:WGS84BoundingBox element when layer extent is unkown, which is non-conformant with WFS XML schema (fix #6170)
Commit: de33bb3744f5418f16b81ace5b17045369477dc3
https://github.com/MapServer/MapServer/commit/de33bb3744f5418f16b81ace5b17045369477dc3
Changed paths:
M mapwfs11.cpp
Log Message:
Merge pull request #6171 from rouault/fix_6170
WFS 1.1/2.0: do not write empty ows:WGS84BoundingBox element when layer extent is unknown
Commit: 9bd402c3596c252195da90a487961b12a15f34c6
https://github.com/MapServer/MapServer/commit/9bd402c3596c252195da90a487961b12a15f34c6
Date: 2020-10-20 (Tue, 20 Oct 2020)
Changed paths:
M cmake/FindOracle.cmake
Log Message:
FindOracle.cmake: complementary fix to find OCI 19
Commit: a4843459d5b9943f25ef8c5680579c3cd575143c
https://github.com/MapServer/MapServer/commit/a4843459d5b9943f25ef8c5680579c3cd575143c
Date: 2020-11-22 (Sun, 22 Nov 2020)
Changed paths:
M mapcontour.c
Log Message:
Contour layer: take into account nodata value from GDAL raster (fixes #6182)
Commit: 612a9d6e36b36c22a9a43faef8bf04771a0f7c74
https://github.com/MapServer/MapServer/commit/612a9d6e36b36c22a9a43faef8bf04771a0f7c74
Date: 2020-11-23 (Mon, 23 Nov 2020)
Changed paths:
M mapcontour.c
Log Message:
Merge pull request #6183 from rouault/mapcontour_nodata
Commit: d11da8d66947f599785eaa25a725210b598c7bff
https://github.com/MapServer/MapServer/commit/d11da8d66947f599785eaa25a725210b598c7bff
Date: 2020-12-02 (Wed, 02 Dec 2020)
Changed paths:
M maptile.h
Log Message:
remove USE_PROJ check
Commit: 750081b554c72ed1f9ba39b53c5067b881169a50
https://github.com/MapServer/MapServer/commit/750081b554c72ed1f9ba39b53c5067b881169a50
Changed paths:
A msautotest/misc/expected/mode_tile_output.png
A msautotest/misc/mode_tile.map
Log Message:
add test for mode_tile
Commit: 3504d9eb1987535b2941d488d335b48911d4c175
https://github.com/MapServer/MapServer/commit/3504d9eb1987535b2941d488d335b48911d4c175
Changed paths:
M INSTALL.CMAKE
Log Message:
update required Cmake version
Commit: 343baadcb0469fc7ccc6efe130d587ca0cd4a823
https://github.com/MapServer/MapServer/commit/343baadcb0469fc7ccc6efe130d587ca0cd4a823
Changed paths:
M MIGRATION_GUIDE.txt
M msautotest/README
Log Message:
minor url changes
Commit: f7bfe597fb982457266e55d2c6318bd05d29ab6a
https://github.com/MapServer/MapServer/commit/f7bfe597fb982457266e55d2c6318bd05d29ab6a
Changed paths:
M README.rst
Log Message:
minor url changes
Commit: 59c31d28608cf9f014dc06fe1ac8cf3a8ae3a71b
https://github.com/MapServer/MapServer/commit/59c31d28608cf9f014dc06fe1ac8cf3a8ae3a71b
Date: 2020-12-04 (Fri, 04 Dec 2020)
Changed paths:
M INSTALL.CMAKE
M README.rst
M msautotest/README
Log Message:
Merge pull request #6188 from jmckenna/versions
Update CMake minimum version required in README
Commit: 7fee6a4665a7a326778d6c339e7c4b5f9d735d9c
https://github.com/MapServer/MapServer/commit/7fee6a4665a7a326778d6c339e7c4b5f9d735d9c
Changed paths:
M msautotest/gdal/wmsclient.map
M msautotest/gdal/wmsclient_3543.map
M msautotest/renderers/wmsclient.map
M msautotest/wxs/wms_client_111.map
M msautotest/wxs/wms_client_111_axis_fail.map
M msautotest/wxs/wms_client_130.map
M msautotest/wxs/wms_client_130_axis_fail.map
Log Message:
switch to https for demo.mapserver.org
Commit: 4e3851199d45889383c4a1eab90d9c79a9dc580a
https://github.com/MapServer/MapServer/commit/4e3851199d45889383c4a1eab90d9c79a9dc580a
Changed paths:
M msautotest/pymod/xmlvalidate.py
M msautotest/requirements.txt
Log Message:
update msautotest for Python3
Commit: e12cb7937f5305169ceb6ec0b7310c8ebc3aa79b
https://github.com/MapServer/MapServer/commit/e12cb7937f5305169ceb6ec0b7310c8ebc3aa79b
Changed paths:
Log Message:
Commit: 75a550e16c37f594efa6a930faec72d0963a663b
https://github.com/MapServer/MapServer/commit/75a550e16c37f594efa6a930faec72d0963a663b
Changed paths:
Log Message:
Merge pull request #6192 from jmckenna/msautotest-demo-https
[msautotest] switch to https for demo.mapserver.org
Commit: 9b6620c6d9b21570c753693927eab1b3222e7bdd
https://github.com/MapServer/MapServer/commit/9b6620c6d9b21570c753693927eab1b3222e7bdd
Changed paths:
Log Message:
Merge branch 'master' of github.com:MapServer/MapServer into msautotest-python3
Commit: 5e0381f7428f93711e5d028eb13657b142fef0e2
https://github.com/MapServer/MapServer/commit/5e0381f7428f93711e5d028eb13657b142fef0e2
Date: 2020-12-07 (Mon, 07 Dec 2020)
Changed paths:
Log Message:
Merge pull request #6194 from jmckenna/msautotest-python3
[msautotest] update xmlvalidate.py for Python3
Commit: c9d7b2f32f7cad806cdbd0b0343eb99f99601dfa
https://github.com/MapServer/MapServer/commit/c9d7b2f32f7cad806cdbd0b0343eb99f99601dfa
Changed paths:
M maptemplate.c
Log Message:
handle memory leaks
Commit: 55bfcf19b8456584c4fb65e7d7f2a4c515303e52
https://github.com/MapServer/MapServer/commit/55bfcf19b8456584c4fb65e7d7f2a4c515303e52
Changed paths:
M maptemplate.c
M maptile.h
Log Message:
Merge pull request #6187 from jmckenna/mode_tile
remove USE_PROJ check for mode=tile
Commit: db4acd5e7055490ceaf021bbcd08ebf5c5cbc312
https://github.com/MapServer/MapServer/commit/db4acd5e7055490ceaf021bbcd08ebf5c5cbc312
Date: 2020-12-13 (Sun, 13 Dec 2020)
Changed paths:
M msautotest/pymod/mstestlib.py
Log Message:
update for Python3
Commit: 7b7df5f2a07b6b050f72b19feecb620ec355ce5d
https://github.com/MapServer/MapServer/commit/7b7df5f2a07b6b050f72b19feecb620ec355ce5d
Changed paths:
Log Message:
Merge pull request #6197 from jmckenna/msautotest-mstestlib
[msautotest] update mstestlib for Python3
Commit: 46080786af3c48189eade17c98e8069706fb7e6e
https://github.com/MapServer/MapServer/commit/46080786af3c48189eade17c98e8069706fb7e6e
Author: Tim Gates <tim.gates at iress.com>
Date: 2020-12-14 (Mon, 14 Dec 2020)
Changed paths:
M renderers/agg/include/agg_rendering_buffer.h
Log Message:
docs: fix simple typo, renrdering -> rendering
There is a small typo in renderers/agg/include/agg_rendering_buffer.h.
Should read `rendering` rather than `renrdering`.
Commit: 6cf513b65aef5ca36be09ec145d811703d88684f
https://github.com/MapServer/MapServer/commit/6cf513b65aef5ca36be09ec145d811703d88684f
Changed paths:
Log Message:
Merge pull request #6198 from timgates42/bugfix_typo_rendering
Commit: 20b7671f788952c6097ae154b667dd564cf70764
https://github.com/MapServer/MapServer/commit/20b7671f788952c6097ae154b667dd564cf70764
Author: Seth G <sethg at geographika.co.uk>
Date: 2020-12-30 (Wed, 30 Dec 2020)
Changed paths:
M maphash.h
M mapscript/python/pyextend.i
M mapscript/swiginc/image.i
M mapserver.h
Log Message:
Document imageObj and hashTableObj (#6168)
Compare: https://github.com/MapServer/MapServer/compare/d7faf8ac85e8%5E...20b7671f7889
More information about the mapserver-commits
