[mapserver-commits] [MapServer/MapServer] 306164: PROJ >= 6 reprojection: fix use of freed memory wh...
Even Rouault
noreply at github.com
Fri Jan 22 05:45:36 PST 2021
Branch: refs/heads/branch-7-6
Home: https://github.com/MapServer/MapServer
Commit: 306164a5d8cb0abf0abaa96d026193a2da7a9ca6
https://github.com/MapServer/MapServer/commit/306164a5d8cb0abf0abaa96d026193a2da7a9ca6
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2021-01-22 (Fri, 22 Jan 2021)
Changed paths:
M mapproject.c
Log Message:
PROJ >= 6 reprojection: fix use of freed memory when input and output projections are the same
Commit: 31dd30f3a6c1bc434367a4cc72094e266370ad19
https://github.com/MapServer/MapServer/commit/31dd30f3a6c1bc434367a4cc72094e266370ad19
Changed paths:
M mapproject.c
Log Message:
Merge pull request #6216 from rouault/branch-7-6-fix_proj6_createNormalizedPJ_same_proj
[branch-7-6] PROJ >= 6 reprojection: fix use of freed memory when input and output projections are the same
Compare: https://github.com/MapServer/MapServer/compare/035df09ecaef...31dd30f3a6c1
More information about the mapserver-commits
