[mapserver-commits] [MapServer/MapServer] c8d57e: shptreetst.c: avoid Coverity warning (CID 1503520)
Jeff McKenna
noreply at github.com
Sun May 16 04:17:54 PDT 2021
Branch: refs/heads/main
Home: https://github.com/MapServer/MapServer
Commit: c8d57eff665dba7905d42e7ae9fca4915771deda
https://github.com/MapServer/MapServer/commit/c8d57eff665dba7905d42e7ae9fca4915771deda
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2021-05-15 (Sat, 15 May 2021)
Changed paths:
M shptreetst.c
Log Message:
Commit: 61d7ce0e08cf29e82cb1907c63d68ee3b2ce65d6
https://github.com/MapServer/MapServer/commit/61d7ce0e08cf29e82cb1907c63d68ee3b2ce65d6
Changed paths:
M maphttp.c
Log Message:
maphttp.c: silence Coverity warning (CID 1503504)
Commit: 0abd3d14d4cad947858b87e9bbd623787fbe6bd6
https://github.com/MapServer/MapServer/commit/0abd3d14d4cad947858b87e9bbd623787fbe6bd6
Changed paths:
M mapogcsld.c
Log Message:
mapogcsld.c: check return value of msInitializeVirtualTable() (CID 1503501)
Commit: f1669f8dfd9073a4d76fa4cb91547e79a41172b9
https://github.com/MapServer/MapServer/commit/f1669f8dfd9073a4d76fa4cb91547e79a41172b9
Changed paths:
M mapchart.c
Log Message:
mapchart.c: remove a useless for construct (CID 1503475)
Commit: ea5318425c3ef3ba1fb3e4d822680afab845d1f2
https://github.com/MapServer/MapServer/commit/ea5318425c3ef3ba1fb3e4d822680afab845d1f2
Changed paths:
M mapwcs20.cpp
Log Message:
mapwcs20.cpp: check return value of msStringParseInteger() (CID 1503469)
Commit: 5c901f8ce372d517d69d28c35259ad31a1c55c33
https://github.com/MapServer/MapServer/commit/5c901f8ce372d517d69d28c35259ad31a1c55c33
Changed paths:
M mapfile.c
Log Message:
mapfile.c: silence warning (CID 1503468)
Commit: 6e58de1eb3ece4be758129353c9fd984c774c07f
https://github.com/MapServer/MapServer/commit/6e58de1eb3ece4be758129353c9fd984c774c07f
Changed paths:
M mapimagemap.c
Log Message:
msDrawMarkerSymbolIM(): cast to appropriate type (CID 1503401)
Commit: ce8c9d6a147f3868c7a0ef099aacdee1fa245a21
https://github.com/MapServer/MapServer/commit/ce8c9d6a147f3868c7a0ef099aacdee1fa245a21
Changed paths:
M mapraster.c
Log Message:
msGetClass_String(): rewrite loop in a less confusing way to solve CID 1503394
Commit: 99d55e1281d358ff2d2592b264c82903905626b6
https://github.com/MapServer/MapServer/commit/99d55e1281d358ff2d2592b264c82903905626b6
Changed paths:
M mapgdal.c
Log Message:
msSaveImageGDAL(): avoid false positive warning about nullptr deref (CID 1503386)
Commit: d1c79af976251b0a8d5bb8fbc7ac497253ea7dbb
https://github.com/MapServer/MapServer/commit/d1c79af976251b0a8d5bb8fbc7ac497253ea7dbb
Changed paths:
M mapchart.c
Log Message:
msDrawChartLayer(): remove useless nullptr check (CID 1503362)
Commit: 897812f8a20427526949cf0100a879760a7972dd
https://github.com/MapServer/MapServer/commit/897812f8a20427526949cf0100a879760a7972dd
Changed paths:
M maphttp.c
Log Message:
maphttp.c: avoid warnings about unchecked return value of curl_easy_setopt() (CID 1503358)
Commit: f7b91d033ebb0066242a7e8ac22c70887d5d047e
https://github.com/MapServer/MapServer/commit/f7b91d033ebb0066242a7e8ac22c70887d5d047e
Changed paths:
M mapwfs.cpp
Log Message:
msWFSRetrieveFeatures(): avoid false positive warning about nullptr deref (CID 1503340)
Commit: ac2cabfd4e87b02dcb3d3d3d4b0d64f62770ca81
https://github.com/MapServer/MapServer/commit/ac2cabfd4e87b02dcb3d3d3d4b0d64f62770ca81
Changed paths:
M mapprimitive.c
Log Message:
Rename/switch variable to be consistent with argument names of compute_retry_offset() (CID 1503339)
Commit: 23cc3bf481f0effc9f2553b7d735e9f2c4efa820
https://github.com/MapServer/MapServer/commit/23cc3bf481f0effc9f2553b7d735e9f2c4efa820
Changed paths:
M mapwms.cpp
Log Message:
mapwms.c: avoid likely false positive warning about div by zero (CID 1503334)
Commit: 05d205a5361643f046df9ee85b489a73c17523c3
https://github.com/MapServer/MapServer/commit/05d205a5361643f046df9ee85b489a73c17523c3
Changed paths:
M mapwfs.cpp
Log Message:
mapwfs.cpp: remove useless nullptr check (CID 1503326)
Commit: 496023d71751ab21abd10252cdd24dcafa75a3ed
https://github.com/MapServer/MapServer/commit/496023d71751ab21abd10252cdd24dcafa75a3ed
Changed paths:
M mapmvt.c
Log Message:
msMVTWriteTile(): fix test condition (CID 1503319)
Commit: f8e8c52ae2784f81f69fd5e33860b95b2c9ef645
https://github.com/MapServer/MapServer/commit/f8e8c52ae2784f81f69fd5e33860b95b2c9ef645
Changed paths:
M mappostgis.cpp
Log Message:
msPostGISReadShape(): avoid dead code warning (CID 1503309)
Commit: f6d9b4e5265a9c0adc99bc73e9df8dce59035461
https://github.com/MapServer/MapServer/commit/f6d9b4e5265a9c0adc99bc73e9df8dce59035461
Changed paths:
M maptime.c
Log Message:
msValidateTimeValue(): avoid identical code in then and else blocks (CID 1503270)
Commit: 1f81ea8a65a2b8f2db1f84cb7307a1cc5dc8d444
https://github.com/MapServer/MapServer/commit/1f81ea8a65a2b8f2db1f84cb7307a1cc5dc8d444
Changed paths:
M mapproject.c
Log Message:
mapproject.c: avoid false positive warning about dead code (CID 1503265)
Commit: 4c33c69feb88b71959c583847a615bd542ff5575
https://github.com/MapServer/MapServer/commit/4c33c69feb88b71959c583847a615bd542ff5575
Changed paths:
M mappostgis.cpp
Log Message:
wkbConvCollectionToShape(): add some validation (CID 1503262)
Commit: 364ffe1b8e8ec1db9791ee77c171870ab1054f51
https://github.com/MapServer/MapServer/commit/364ffe1b8e8ec1db9791ee77c171870ab1054f51
Changed paths:
M mapproject.c
Log Message:
msProjectShapeShouldDoLineCutting(): silence false positive warning (CID 1503239)
Commit: c538dd48b6560105ee3e715676e51d8918fd9ca0
https://github.com/MapServer/MapServer/commit/c538dd48b6560105ee3e715676e51d8918fd9ca0
Changed paths:
M mapwms.cpp
Log Message:
mapwms.cpp: avoid false positive warning about copy and paste error (CID 1503220)
Commit: f98c3336e322b8ab255c542a7471652945bb58e1
https://github.com/MapServer/MapServer/commit/f98c3336e322b8ab255c542a7471652945bb58e1
Changed paths:
M maputfgrid.h
Log Message:
maputfgrid.h: initialize member variable (CID 1194603)
Commit: 22a0d295686c20dc5176dfa37f3769a2813efab1
https://github.com/MapServer/MapServer/commit/22a0d295686c20dc5176dfa37f3769a2813efab1
Changed paths:
M maplabel.c
Log Message:
msAddLabel(): add assertion against potential nullptr deref (CID 1194593)
Commit: 3300882f958d281d56fb8b1015479073451ca025
https://github.com/MapServer/MapServer/commit/3300882f958d281d56fb8b1015479073451ca025
Changed paths:
M maplabel.c
Log Message:
msCopyTextSymbol(): rewrite checks in an equivalent but clearer way (CID 1194592)
Commit: 0d58e6e8532c46b0fa86b2d37646f6440999f61e
https://github.com/MapServer/MapServer/commit/0d58e6e8532c46b0fa86b2d37646f6440999f61e
Changed paths:
M maprendering.c
Log Message:
getTile(): remove dead code (CID 1194589)
Commit: 35d4084ede678cf107b0d111c5e82e586d82e1e2
https://github.com/MapServer/MapServer/commit/35d4084ede678cf107b0d111c5e82e586d82e1e2
Changed paths:
M mapwfs11.cpp
Log Message:
msWFSDumpLayer11(): remove dead code (CID 1175264)
Commit: 55dcfd66f3f1b837e8d44f6257fcfa66ca0369ba
https://github.com/MapServer/MapServer/commit/55dcfd66f3f1b837e8d44f6257fcfa66ca0369ba
Changed paths:
M mapxmp.c
Log Message:
msXmpWrite(): avoid false positive warning about nullptr deref (CID 1175242)
Commit: 359c4a2c6cd0b89ee48d512f9d52658e55f453df
https://github.com/MapServer/MapServer/commit/359c4a2c6cd0b89ee48d512f9d52658e55f453df
Changed paths:
M maptemplate.c
Log Message:
maptemplate.c: silence false positive warning (CID 1174974)
Commit: 1bd99d2b4a377d59a5f3e918e6c21337d2c71fc0
https://github.com/MapServer/MapServer/commit/1bd99d2b4a377d59a5f3e918e6c21337d2c71fc0
Changed paths:
M mapdraw.c
Log Message:
mapwms.cpp: avoid false positive warning about nullptr deref (CID 1174977)
Commit: c862b04cf690091995df40139a6be77a2ff72bce
https://github.com/MapServer/MapServer/commit/c862b04cf690091995df40139a6be77a2ff72bce
Author: Jeff McKenna <jmckenna at gatewaygeomatics.com>
Date: 2021-05-16 (Sun, 16 May 2021)
Changed paths:
M mapchart.c
M mapdraw.c
M mapfile.c
M mapgdal.c
M maphttp.c
M mapimagemap.c
M maplabel.c
M mapmvt.c
M mapogcsld.c
M mappostgis.cpp
M mapprimitive.c
M mapproject.c
M mapraster.c
M maprendering.c
M maptemplate.c
M maptime.c
M maputfgrid.h
M mapwcs20.cpp
M mapwfs.cpp
M mapwfs11.cpp
M mapwms.cpp
M mapxmp.c
M shptreetst.c
Log Message:
Merge pull request #6330 from rouault/coverity_scan_fixes
Another batch of Coverity scan fixes
Compare: https://github.com/MapServer/MapServer/compare/9d086cacc2df...c862b04cf690
More information about the mapserver-commits
