[mapserver-commits] [MapServer/MapServer] ecc2a6: rename to map2img
Jeff McKenna noreply at github.com
Thu Oct 7 05:35:52 PDT 2021
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: ecc2a6e3c649f3a4b8b1e73862d5acb3090a5e57
      https://github.com/MapServer/MapServer/commit/ecc2a6e3c649f3a4b8b1e73862d5acb3090a5e57
  Author: jmckenna <jmckenna at gatewaygeomatics.com>
  Date:   2021-09-14 (Tue, 14 Sep 2021)
  Changed paths:
    M .github/ISSUE_TEMPLATE.md
    M CMakeLists.txt
    M ci/travis/after_success.sh
    M ci/travis/script.sh
    A map2img.c
    M mapserver-config.cmake.in
    M msautotest/gdal/class8_range.map
    M msautotest/misc/attrbind.map
    M msautotest/misc/bug1526.map
    M msautotest/misc/encoding.map
    M msautotest/misc/geopdf.map
    M msautotest/misc/issue5558.map
    A msautotest/misc/map2img-size.map
    M msautotest/misc/maxfeatures.map
    M msautotest/misc/scaletoken.map
    R msautotest/misc/shp2img-size.map
    M msautotest/misc/style_opacity.map
    M msautotest/msoracle/oracle.map
    M msautotest/mssql/cluster_mssql.map
    M msautotest/mssql/filters_mssql.map
    M msautotest/php/maps/filter.map
    M msautotest/php/maps/filters.map
    M msautotest/php/maps/style_opacity.map
    M msautotest/pymod/mstestlib.py
    M msautotest/query/context.map
    M msautotest/query/filters.map
    M msautotest/query/filters_postgis.map
    M msautotest/query/text.map
    M msautotest/renderers/average_rgb.map
    M msautotest/renderers/baseline_text.map
    M msautotest/renderers/chartlayer_bar.map
    M msautotest/renderers/chartlayer_pie.map
    M msautotest/renderers/chartlayer_pie2.map
    M msautotest/renderers/chartlayer_pie_expressions.map
    M msautotest/renderers/chartlayer_vbar.map
    M msautotest/renderers/circle_layer.map
    M msautotest/renderers/compositing.map
    M msautotest/renderers/embed_legend.map
    M msautotest/renderers/embed_legend_rgba.map
    M msautotest/renderers/embed_legend_rgba_tr.map
    M msautotest/renderers/embed_legend_tr.map
    M msautotest/renderers/embed_sb_rgb.map
    M msautotest/renderers/embed_sb_rgb_tr.map
    M msautotest/renderers/embed_sb_rgba.map
    M msautotest/renderers/embed_sb_rgba_offset.map
    M msautotest/renderers/embed_sb_rgba_tr.map
    M msautotest/renderers/empty.map
    M msautotest/renderers/entity_encoded_follow_text.map
    M msautotest/renderers/font-fail.map
    M msautotest/renderers/force_palette.map
    M msautotest/renderers/force_palette_rgba.map
    M msautotest/renderers/force_pc256.map
    M msautotest/renderers/force_pc256_rgba.map
    M msautotest/renderers/geomtransform-vertex.map
    M msautotest/renderers/grid.map
    M msautotest/renderers/label-multifont.map
    M msautotest/renderers/label_noclip.map
    M msautotest/renderers/labelcacheoff.map
    M msautotest/renderers/labelpnt.map
    M msautotest/renderers/labelrot.map
    M msautotest/renderers/labels-alignment.map
    M msautotest/renderers/labels-anno.map
    M msautotest/renderers/labels-attribute-alignment-offset.map
    M msautotest/renderers/labels-bitmap-multiline.map
    M msautotest/renderers/labels-bitmap.map
    M msautotest/renderers/labels-leader.map
    M msautotest/renderers/labels-min-distance.map
    M msautotest/renderers/labels-wrap.map
    M msautotest/renderers/labels.map
    M msautotest/renderers/line_aliased.map
    M msautotest/renderers/line_anchorpoint.map
    M msautotest/renderers/line_antialiased.map
    M msautotest/renderers/line_label_auto.map
    M msautotest/renderers/line_label_auto2.map
    M msautotest/renderers/line_label_follow.map
    M msautotest/renderers/line_label_follow_offsetted.map
    M msautotest/renderers/line_label_follow_retry.map
    M msautotest/renderers/line_marker_pixmap.map
    M msautotest/renderers/line_marker_svg.map
    M msautotest/renderers/line_marker_truetype.map
    M msautotest/renderers/line_marker_vector.map
    M msautotest/renderers/line_offset.map
    M msautotest/renderers/line_pattern.map
    M msautotest/renderers/line_pattern_offset.map
    M msautotest/renderers/line_short_gap.map
    M msautotest/renderers/line_simple.map
    M msautotest/renderers/lots_of_text.map
    M msautotest/renderers/marker_anchorpoint.map
    M msautotest/renderers/marker_pixmap.map
    M msautotest/renderers/mask.map
    M msautotest/renderers/mask_opacity.map
    M msautotest/renderers/multilabel-leader.map
    M msautotest/renderers/multilabel.map
    M msautotest/renderers/nodata_8bit.map
    M msautotest/renderers/plb_embed_legend.map
    M msautotest/renderers/plb_embed_legend_rgba.map
    M msautotest/renderers/plb_embed_legend_rgba_tr.map
    M msautotest/renderers/plb_embed_legend_tr.map
    M msautotest/renderers/point-polaroffset.map
    M msautotest/renderers/point_ellipse.map
    M msautotest/renderers/point_pixmap.map
    M msautotest/renderers/point_pixmap_gif.map
    M msautotest/renderers/point_svg.map
    M msautotest/renderers/point_truetype.map
    M msautotest/renderers/point_vector.map
    M msautotest/renderers/poly-label-multiline-pos-auto.map
    M msautotest/renderers/poly-label-pos-auto.map
    M msautotest/renderers/poly_geomtransform_anchor.map
    M msautotest/renderers/polygon-as-line-offset.map
    M msautotest/renderers/polygon-as-line.map
    M msautotest/renderers/polygon-hatch-dashed.map
    M msautotest/renderers/polygon-hatch.map
    M msautotest/renderers/polygon-hex-alpha.map
    M msautotest/renderers/polygon-pixmap.map
    M msautotest/renderers/polygon-simple.map
    M msautotest/renderers/polygon-ttf.map
    M msautotest/renderers/polygon-vector.map
    M msautotest/renderers/polyline_no_clip.map
    M msautotest/renderers/raster_simple.map
    M msautotest/renderers/raster_simple_opacity.map
    M msautotest/renderers/reproj.map
    M msautotest/renderers/rgb_overlay.map
    M msautotest/renderers/rgb_overlay_res.map
    M msautotest/renderers/rgb_overlay_res_to8bit.map
    M msautotest/renderers/rgb_overlay_res_to8bit_dithered.map
    M msautotest/renderers/rgba_overlay_res.map
    M msautotest/renderers/symbolrot.map
    M msautotest/renderers/text-shaping.map
    M msautotest/renderers/transparent_layer.map
    M msautotest/renderers/utfgrid-escaping.map
    M msautotest/renderers/utfgrid_truetype_symbol.map
    M msautotest/renderers/uvraster.map
    M msautotest/renderers/uvraster_reproj.map
    M msautotest/renderers/wld_rotate.map
    M msautotest/renderers/wld_upsidedown.map
    M msautotest/renderers/wmsclient.map
  Log Message:
  rename to map2img
  Commit: 93fc04884248781f393aac6221301dcebe9204cd
      https://github.com/MapServer/MapServer/commit/93fc04884248781f393aac6221301dcebe9204cd
  Changed paths:
    M tests/README
  Log Message:
  rename to map2img
  Commit: ece0ff126a7afcf6c805731f1238343fa718d307
      https://github.com/MapServer/MapServer/commit/ece0ff126a7afcf6c805731f1238343fa718d307
  Changed paths:
    R shp2img.c
  Log Message:
  rename to map2img
  Commit: fc1287f05d6b2be3c24e9678e03679f2f15025d4
      https://github.com/MapServer/MapServer/commit/fc1287f05d6b2be3c24e9678e03679f2f15025d4
  Changed paths:
    R msautotest/misc/expected/shp2img-size.gif
    R msautotest/misc/expected/shp2img-size.png
  Log Message:
  fix msautotest
  Commit: 65dea75cbed8380de9f6a44c1ada1d382e15c60a
      https://github.com/MapServer/MapServer/commit/65dea75cbed8380de9f6a44c1ada1d382e15c60a
  Changed paths:
    A msautotest/misc/expected/map2img-size.gif
    A msautotest/misc/expected/map2img-size.png
  Log Message:
  fix msautotest
  Commit: b8c2da496bdbe05a1f33b38ec5659226bf6ab070
      https://github.com/MapServer/MapServer/commit/b8c2da496bdbe05a1f33b38ec5659226bf6ab070
  Author: Jeff McKenna <jeffmckenna at gmail.com>
  Date:   2021-10-07 (Thu, 07 Oct 2021)
  Changed paths:
    M CMakeLists.txt
    M appveyor.yml
    M ci/travis/before_install.sh
    M mapogcapi.cpp
    M mapogr.cpp
    M mapscript/python/CMakeLists.txt
    M msautotest/api/expected/ogcapi_collections_mn_counties_items_limit_1_offset_2.json
    A msautotest/wxs/expected/wfs_ogr_gpkg_filter_intersects_point.xml
    M msautotest/wxs/wfs_ogr_gpkg.map
    M share/ogcapi/templates/html-bootstrap4/collection-item.html
    M share/ogcapi/templates/html-bootstrap4/collection-items.html
    M share/ogcapi/templates/html-bootstrap4/collection.html
    M share/ogcapi/templates/html-bootstrap4/footer.html
    M share/ogcapi/templates/html-bootstrap4/header.html
    M third-party/pantor/inja.hpp
  Log Message:
  Merge branch 'MapServer:main' into map2img
  Commit: fb79b150336726d4c50e511c6465b0086efdc6e8
      https://github.com/MapServer/MapServer/commit/fb79b150336726d4c50e511c6465b0086efdc6e8
  Author: Jeff McKenna <jmckenna at gatewaygeomatics.com>
  Changed paths:
    M CMakeLists.txt
    A map2img.c
    R shp2img.c
    M tests/README
  Log Message:
  Merge pull request #6409 from jmckenna/map2img
rename shp2img to map2img
Compare: https://github.com/MapServer/MapServer/compare/be30a068fab3...fb79b1503367
