[mapserver-commits] [MapServer/MapServer] 91b892: map2img: initialize error file before msLoadConfig...
Even Rouault
noreply at github.com
Thu Oct 28 06:27:01 PDT 2021
Branch: refs/heads/main
Home: https://github.com/MapServer/MapServer
Commit: 91b892f7992f4eeae99953469d575a61d57d732a
https://github.com/MapServer/MapServer/commit/91b892f7992f4eeae99953469d575a61d57d732a
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2021-10-26 (Tue, 26 Oct 2021)
Changed paths:
M map2img.c
Log Message:
map2img: initialize error file before msLoadConfig() so that -map_debug / -layer_debug warn about missing config file
Commit: 4d3dc95fd71bc2801ab9dbd99cec04b70e83d233
https://github.com/MapServer/MapServer/commit/4d3dc95fd71bc2801ab9dbd99cec04b70e83d233
Changed paths:
M map2img.c
Log Message:
map2img: add a -conf filename option to set configuration file
Commit: 72e009e4fa528135658d645ec9b993d00ef18fdc
https://github.com/MapServer/MapServer/commit/72e009e4fa528135658d645ec9b993d00ef18fdc
Date: 2021-10-27 (Wed, 27 Oct 2021)
Changed paths:
M mapserv-config.cpp
Log Message:
msLoadConfig(): display path to config file, as debug message, when it cannot be opened
Commit: dd5165028c96b9c490b2d13f24dcb9763eb5c7c0
https://github.com/MapServer/MapServer/commit/dd5165028c96b9c490b2d13f24dcb9763eb5c7c0
Changed paths:
M .github/workflows/start.sh
M mapserv.c
Log Message:
mapserv: add a -conf filename option to set configuration file
Commit: 442d763183ca31e729eefc3de6a1c73cd14339b5
https://github.com/MapServer/MapServer/commit/442d763183ca31e729eefc3de6a1c73cd14339b5
Changed paths:
M mapserv.c
Log Message:
mapserv: do not parse command line arguments at all when QUERY_STRING env variable is set
Commit: 2d06af06f72aac4bc4f13640ff05543eeada9e62
https://github.com/MapServer/MapServer/commit/2d06af06f72aac4bc4f13640ff05543eeada9e62
Date: 2021-10-28 (Thu, 28 Oct 2021)
Changed paths:
M map2img.c
M mapserv.c
Log Message:
Merge pull request #6429 from rouault/config_file_reports_improvements
Config file reports improvements
Compare: https://github.com/MapServer/MapServer/compare/b3e340ddebb9...2d06af06f72a
More information about the mapserver-commits
