[mapserver-commits] [MapServer/MapServer] ee952f: Fixed MS_MAP_PATTERN check.
Jeff McKenna noreply at github.com
Fri Feb 25 08:52:19 PST 2022
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: ee952f850f0c1c134b5787a88c1639e37abff49e
      https://github.com/MapServer/MapServer/commit/ee952f850f0c1c134b5787a88c1639e37abff49e
  Author: Steve Lime <steve.lime at state.mn.us>
  Date:   2022-02-15 (Tue, 15 Feb 2022)
  Changed paths:
    M mapservutil.c
  Log Message:
  Commit: b16ac2a46d6e7f3c808be98ce11109862bc1253b
      https://github.com/MapServer/MapServer/commit/b16ac2a46d6e7f3c808be98ce11109862bc1253b
  Changed paths:
    A msautotest/config/empty1.conf
    A msautotest/config/empty2.conf
    A msautotest/config/expected/empty1_conf.txt
    A msautotest/config/expected/empty2_conf.txt
    A msautotest/config/expected/hello_world.png
    A msautotest/config/expected/invalid1_conf.txt
    A msautotest/config/expected/invalid2_conf.txt
    A msautotest/config/expected/missing_conf.txt
    A msautotest/config/expected/ms_map_no_path1_conf.txt
    A msautotest/config/expected/ms_map_no_path2_conf_failure1.txt
    A msautotest/config/expected/ms_map_no_path2_conf_failure2.txt
    A msautotest/config/expected/ms_map_no_path2_conf_success.png
    A msautotest/config/expected/ms_map_pattern_conf.txt
    A msautotest/config/expected/ms_map_pattern_conf_bad_regex.txt
    A msautotest/config/hello_world.map
    A msautotest/config/invalid1.conf
    A msautotest/config/invalid2.conf
    A msautotest/config/ms_map_no_path1.conf
    A msautotest/config/ms_map_no_path2.conf
    A msautotest/config/ms_map_pattern.conf
    A msautotest/config/ms_map_pattern_bad_regex.conf
    A msautotest/config/run_test.py
  Log Message:
  Added configuration file tests.
  Commit: 366a3705307e071facc53b844a5570b10c9cfe6a
      https://github.com/MapServer/MapServer/commit/366a3705307e071facc53b844a5570b10c9cfe6a
  Date:   2022-02-16 (Wed, 16 Feb 2022)
  Changed paths:
    M Makefile
    M msautotest/pytest.ini
  Log Message:
  Enable config tests.
  Commit: 24e05b27bd0d41510f8cc175adb3ef74aee4cd9b
      https://github.com/MapServer/MapServer/commit/24e05b27bd0d41510f8cc175adb3ef74aee4cd9b
  Changed paths:
    M Makefile
  Log Message:
  Flipping spaces instead of tab... fixed.
  Commit: 041a29be66eac78273c67cae60a1a63c77a1594a
      https://github.com/MapServer/MapServer/commit/041a29be66eac78273c67cae60a1a63c77a1594a
  Changed paths:
    A msautotest/config/expected/hello_world_post.png
    A msautotest/config/expected/ms_no_post_conf_failure.txt
    A msautotest/config/expected/ms_no_post_conf_success.png
    M msautotest/config/hello_world.map
  Log Message:
  Added baseline POST test and MS_NO_POST test.
  Commit: d1103f38cdcecd741e7235c51e9313520efcd09e
      https://github.com/MapServer/MapServer/commit/d1103f38cdcecd741e7235c51e9313520efcd09e
  Date:   2022-02-18 (Fri, 18 Feb 2022)
  Changed paths:
    M mapservutil.c
    M msautotest/config/expected/empty2_conf.txt
  Log Message:
  Set explicit error message when MS_MAP_PATTERN is required but not set.
  Commit: 01edf348bb93fbcdbf9fce1db1d24455629428b7
      https://github.com/MapServer/MapServer/commit/01edf348bb93fbcdbf9fce1db1d24455629428b7
  Date:   2022-02-22 (Tue, 22 Feb 2022)
  Changed paths:
    A msautotest/config/ms_no_post.conf
  Log Message:
  Test config file for MS_NO_POST option.
  Commit: aa915ae9862d63967ffbbf6a107aa7a8d2a1a173
      https://github.com/MapServer/MapServer/commit/aa915ae9862d63967ffbbf6a107aa7a8d2a1a173
  Changed paths:
    M etc/mapserver-sample.conf
    M maperror.c
    M mapogcsos.c
    M mapservutil.c
    M mapwfs.cpp
    M mapwms.cpp
    A msautotest/config/expected/ms_no_version_conf.txt
    A msautotest/config/ms_no_version.conf
  Log Message:
  Implementation and tests for MS_NO_VERSION option.
  Commit: f9c64ebf8da527dd8ebd26a804ff79bb0a9f89fc
      https://github.com/MapServer/MapServer/commit/f9c64ebf8da527dd8ebd26a804ff79bb0a9f89fc
  Date:   2022-02-24 (Thu, 24 Feb 2022)
  Changed paths:
    A msautotest/api/__init__.py
    A msautotest/config/__init__.py
  Log Message:
  Added empty __init__.py files - fixes running tests in vagrant.
  Commit: 6914d791c47eda73ea67bcbae2604ba36b708711
      https://github.com/MapServer/MapServer/commit/6914d791c47eda73ea67bcbae2604ba36b708711
  Author: Jeff McKenna <jmckenna at gatewaygeomatics.com>
  Date:   2022-02-25 (Fri, 25 Feb 2022)
  Changed paths:
    M Makefile
    M maperror.c
    M mapogcsos.c
    M mapservutil.c
    M mapwfs.cpp
    M mapwms.cpp
  Log Message:
  Merge pull request #6480 from sdlime/config-tests
Added series of configuration file tests...
Compare: https://github.com/MapServer/MapServer/compare/1901a8216749...6914d791c47e
More information about the MapServer-commits mailing list
