[mapserver-commits] [MapServer/MapServer] 50aaec: Fix style scale factor inheritance
Māris Nartišs
noreply at github.com
Sun Jul 28 07:24:27 PDT 2024
Branch: refs/heads/backport-7115-to-branch-8-2
Home: https://github.com/MapServer/MapServer
Commit: 50aaec6ad4493855f4371d1aa750e9ca8b5311ee
https://github.com/MapServer/MapServer/commit/50aaec6ad4493855f4371d1aa750e9ca8b5311ee
Author: Māris Nartišs <maris.gis at gmail.com>
Date: 2024-07-28 (Sun, 28 Jul 2024)
Changed paths:
M src/mapdraw.c
M src/maplayer.c
M src/mapserver.h
Log Message:
Commit ede4953 introduced SIZEUNITS inheritance layer->class->style/label.
When LAYER STYLEITEM is in use, for each feature msUpdateStyleFromString
is called but no attempts are made to ensure correct scale factor values
for newly created style item thus all features get scale factor 1.0,
that might be different from value it should have. This wasn't a problem
before ede4953 as layer scale factor was always used to render features
with STYLEITEM.
This commit introduces a workaround by lifting out code from the only
place where scale factor is adjusted in a way that it can be reused also
in the STYLEITEM case.
Commit: 246eb8f1f8e64a67ad2faec59e22a19a100e0609
https://github.com/MapServer/MapServer/commit/246eb8f1f8e64a67ad2faec59e22a19a100e0609
Changed paths:
A msautotest/misc/data/styleitem_style.csv
A msautotest/misc/expected/scale_factor_inheritance.png
A msautotest/misc/scale_factor_inheritance.map
Log Message:
A test case for style scalefactor correct inheritance when STYLEITEM is in use
Commit: fba4470674ce7726678c24d37e7fc8fbc4214037
https://github.com/MapServer/MapServer/commit/fba4470674ce7726678c24d37e7fc8fbc4214037
Changed paths:
M src/mapdraw.c
Log Message:
Fix code formatting
Commit: 71016a39473ac973f2a95d5216f7b549701d5b12
https://github.com/MapServer/MapServer/commit/71016a39473ac973f2a95d5216f7b549701d5b12
Changed paths:
M src/maplayer.c
M src/mapserver.h
Log Message:
Code formatting fix for two more files
Compare: https://github.com/MapServer/MapServer/compare/50aaec6ad449%5E...71016a39473a
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits
