[mapserver-commits] [MapServer/MapServer] 63ad0a: OGR output format: avoid potential stack buffer ov...
Even Rouault noreply at github.com
Mon Jun 10 14:34:36 PDT 2024
  Branch: refs/heads/branch-7-6
  Home:   https://github.com/MapServer/MapServer
  Commit: 63ad0ab801cf70c1ca0a8aca69e0987f4382dcdb
      https://github.com/MapServer/MapServer/commit/63ad0ab801cf70c1ca0a8aca69e0987f4382dcdb
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2024-06-10 (Mon, 10 Jun 2024)
  Changed paths:
    M mapogroutput.cpp
  Log Message:
  OGR output format: avoid potential stack buffer overflow on too long filename
  Commit: 7b4f1b0df83ea1a225217226d741fa26e8654b8a
      https://github.com/MapServer/MapServer/commit/7b4f1b0df83ea1a225217226d741fa26e8654b8a
  Changed paths:
    M mapregex.c
    M mapregex.h
    M msautotest/query/expected/rfc62_test003.txt
  Log Message:
  mapregex.c: fix invalid mapping of MS_REG_NOSUB and MS_REG_NEWLINE with GNU regex
  Commit: 9e53609fe3be8d4c73b808856552335da9b47916
      https://github.com/MapServer/MapServer/commit/9e53609fe3be8d4c73b808856552335da9b47916
  Changed paths:
    M mapogroutput.cpp
    M mapregex.c
    M mapregex.h
  Log Message:
  Merge pull request #7078 from rouault/backport-7075-to-branch-7-6
[Backport branch-7-6] Security fixes
Compare: https://github.com/MapServer/MapServer/compare/3bfaddbde45d...9e53609fe3be
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits mailing list
