[mapserver-commits] [MapServer/MapServer] 1051da: Raster rendering: skip Byte alpha band with PROCES...
Even Rouault noreply at github.com
Tue Jun 11 08:57:48 PDT 2024
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: 1051da4f183b7697d8b468b0b60143188f3afe54
      https://github.com/MapServer/MapServer/commit/1051da4f183b7697d8b468b0b60143188f3afe54
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2024-05-31 (Fri, 31 May 2024)
  Changed paths:
    A msautotest/gdal/data/rgba_alpha_all_255.tif
    A msautotest/gdal/expected/processing_scale_auto_alpha_255.png
    A msautotest/gdal/processing_scale_auto_alpha_255.map
    M src/mapdrawgdal.c
  Log Message:
  Raster rendering: skip Byte alpha band with PROCESSING "SCALE=AUTO"
Currently when using PROCESSING "SCALE=AUTO" on a raster with an alpha
band, the alpha band is all scaled, which is undesirable, in particular
if it is fully opaque, as the result of auto scaling on it is to
generate a fully transparent result.
  Commit: e06dda5820296bea67aba364bbfca190a7ce0bfd
      https://github.com/MapServer/MapServer/commit/e06dda5820296bea67aba364bbfca190a7ce0bfd
  Date:   2024-06-11 (Tue, 11 Jun 2024)
  Changed paths:
    M src/mapdrawgdal.c
  Log Message:
  Merge pull request #7067 from rouault/scale_auto_rgba
Compare: https://github.com/MapServer/MapServer/compare/7fee5995a1f9...e06dda582029
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits mailing list
