[mapserver-commits] [MapServer/MapServer] d1c272: flatgeobuf: fix out of bounds read after index sea...
Even Rouault noreply at github.com
Sat Mar 9 16:05:50 PST 2024
  Branch: refs/heads/backport-7040-to-branch-8-0
  Home:   https://github.com/MapServer/MapServer
  Commit: d1c2723091c874d48a2707f0bf4fd624ef08afda
      https://github.com/MapServer/MapServer/commit/d1c2723091c874d48a2707f0bf4fd624ef08afda
  Author: Paul Pazderski <paul at ppazderski.de>
  Date:   2024-03-10 (Sun, 10 Mar 2024)
  Changed paths:
    M mapflatgeobuf.c
    A msautotest/misc/expected/flatgeobuf-ocean.png
    M msautotest/misc/flatgeobuf.map
  Log Message:
  flatgeobuf: fix out of bounds read after index search without results
This bug has multiple layers. If an index search is performed in
msFlatGeobufLayerWhichShapes and the search has no result then
flatgeobuf_index_search will set search_result_len to zero but also
allocate a buffer for zero results.
Such a zero size allocation can return a null pointer or a pointer to
a random location. Both cases were problematic.
msFlatGeobufLayerNextShape interprets a null pointer as search_result as
index was skipped and will try to read all features but the file handle
is at the wrong offset if the index was actually used.
If search_result was given a non-null pointer msFlatGeobufLayerNextShape
will check if there are more results found with the following condition:
  if (ctx->search_index >= ctx->search_result_len - 1)
    return MS_DONE;
With an empty search the result length is zero and because it is unsigned
it will underflow and check return false. As consequence it will read the
first search result where none is.
The outcome is that item.offset is a random value and either the following
seek fails (which results in a maperror) or if it succeeds the following
read most likely fails with an EOF (which then produces the correct output
by accident and no error) or if the read succeeds the following buffer
allocation most likely fails as "too huge" or if that also succeeds decoding
of the next feature will most likely fail.
  Commit: 370e66c6517acb348308662f95f567fb8fdd1868
      https://github.com/MapServer/MapServer/commit/370e66c6517acb348308662f95f567fb8fdd1868
  Author: Even Rouault <even.rouault at spatialys.com>
  Changed paths:
  Log Message:
  Update msautotest/misc/flatgeobuf.map
Compare: https://github.com/MapServer/MapServer/compare/d1c2723091c8%5E...370e66c6517a
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits mailing list
