[mapserver-commits] [MapServer/MapServer] 12dfa9: SLD: fix having a TextSymbolizer rule after a Poly...
    Even Rouault
    noreply at github.com
    Fri Oct 18 07:05:44 PDT 2024
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: 12dfa91c8250592aed4951280d7cc06c44921d25
      https://github.com/MapServer/MapServer/commit/12dfa91c8250592aed4951280d7cc06c44921d25
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2024-10-17 (Thu, 17 Oct 2024)
  Changed paths:
    M msautotest/sld/label.map
    M src/mapogcsld.cpp
  Log Message:
  SLD: fix having a TextSymbolizer rule after a PolygonSymbolizer one
Currently if we have a SLD like:
```xml
<NamedLayer>
        <Name>...</Name>
        <UserStyle>
            <Title>default</Title>
            <FeatureTypeStyle>
                <Rule>
                    <PolygonSymbolizer>...</PolygonSymbolizer>
                </Rule>
                <Rule>
                    <TextSymbolizer>...</TextSymbolizer>
                </Rule>
            </FeatureTypeStyle>
        </UserStyle>
    </NamedLayer>
</StyledLayerDescriptor>
the PolygonSymbolizer rule is no applied, only the TextSymolizer one.
This is due to the logic in msSLDParseRule() that inappropriately
overrides the layerObj::type member.
  Commit: 8537ff4bc9a3fa2e70e3b9c01603ae440766c449
      https://github.com/MapServer/MapServer/commit/8537ff4bc9a3fa2e70e3b9c01603ae440766c449
  Date:   2024-10-18 (Fri, 18 Oct 2024)
  Changed paths:
    M src/mapogcsld.cpp
  Log Message:
  Merge pull request #7175 from rouault/RulePolygonSymbolizeRuleTextSymbolizer
Compare: https://github.com/MapServer/MapServer/compare/e6a3c9e7067f...8537ff4bc9a3
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits
