[mapserver-commits] [MapServer/MapServer] 2489fd: uvraster: improve efficiency of GetShape()
Even Rouault
noreply at github.com
Fri Sep 6 06:55:20 PDT 2024
Branch: refs/heads/main
Home: https://github.com/MapServer/MapServer
Commit: 2489fdb02b9e66ced706dd608b0dda945f24ae6a
https://github.com/MapServer/MapServer/commit/2489fdb02b9e66ced706dd608b0dda945f24ae6a
Author: Even Rouault <even.rouault at spatialys.com>
Date: 2024-08-30 (Fri, 30 Aug 2024)
Changed paths:
M CMakeLists.txt
R msautotest/renderers/expected/uvraster.pdf
R msautotest/renderers/expected/uvraster.svg
R msautotest/renderers/expected/uvraster_reproj.pdf
R msautotest/renderers/expected/uvraster_reproj.svg
M msautotest/renderers/uvraster.map
M msautotest/renderers/uvraster_reproj.map
R src/mapuvraster.c
A src/mapuvraster.cpp
Log Message:
Commit: 32b46a177bc1f60facfc3b1976719ce2c37062b0
https://github.com/MapServer/MapServer/commit/32b46a177bc1f60facfc3b1976719ce2c37062b0
Changed paths:
M CMakeLists.txt
A msautotest/renderers/data/temperature.tif
A msautotest/renderers/expected/rasterlabel.png
A msautotest/renderers/rasterlabel.map
M src/mapdraw.c
M src/mapfile.c
M src/maplayer.c
M src/maplexer.c
M src/maplexer.l
A src/maprasterlabel.cpp
M src/mapserver.h
M src/mapuvraster.cpp
Log Message:
Add CONNECTIONTYPE RASTERLABEL
This adds a new CONNECTIONTYPE to be able to display labels based on
raster content.
The code is similar to UVRASTER.
Commit: 21101e125f1c3af4379e60974d629924b062c53c
https://github.com/MapServer/MapServer/commit/21101e125f1c3af4379e60974d629924b062c53c
Changed paths:
A msautotest/wxs/expected/wms_getstyles2.xml
M msautotest/wxs/wms_styles.map
M src/mapogcsld.cpp
Log Message:
msSLDGenerateTextSLD(): avoid crash on expressions of LABEL we can't transform to SLD
but there's a memory leak
Direct leak of 42 byte(s) in 1 object(s) allocated from:
#0 0x7efd24675c3e in __interceptor_realloc ../../../../src/libsanitizer/asan/asan_malloc_linux.cc:163
#1 0x7efd23473913 in msStringConcatenate /home/runner/work/MapServer/MapServer/src/mapstring.cpp:1428
#2 0x7efd2346c344 in yylex src/mapparser.y:1094
#3 0x7efd23460946 in yyparse /home/runner/work/MapServer/MapServer/src/mapparser.c:1584
#4 0x7efd237a32bb in msSLDGenerateTextSLD /home/runner/work/MapServer/MapServer/src/mapogcsld.cpp:4231
#5 0x7efd237a6b7d in msSLDGenerateUserStyle /home/runner/work/MapServer/MapServer/src/mapogcsld.cpp:4575
#6 0x7efd237a7438 in msSLDGenerateSLDLayer /home/runner/work/MapServer/MapServer/src/mapogcsld.cpp:4642
#7 0x7efd2379ba41 in msSLDGenerateSLD /home/runner/work/MapServer/MapServer/src/mapogcsld.cpp:3445
#8 0x7efd23162ec0 in msWMSGetStyles /home/runner/work/MapServer/MapServer/src/mapwms.cpp:5474
#9 0x7efd23165527 in msWMSDispatch /home/runner/work/MapServer/MapServer/src/mapwms.cpp:5777
#10 0x7efd231b6144 in msOWSDispatch /home/runner/work/MapServer/MapServer/src/mapows.c:290
#11 0x7efd2342c89d in msCGIDispatchRequest /home/runner/work/MapServer/MapServer/src/mapservutil.c:2240
#12 0x5589f3102f00 in main /home/runner/work/MapServer/MapServer/src/apps/mapserv.c:294
#13 0x7efd22788082 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x24082)
Commit: 96e8df8cf1ea1a26e13d5b1eeb69a111581c87ed
https://github.com/MapServer/MapServer/commit/96e8df8cf1ea1a26e13d5b1eeb69a111581c87ed
Date: 2024-09-06 (Fri, 06 Sep 2024)
Changed paths:
M CMakeLists.txt
M src/mapdraw.c
M src/mapfile.c
M src/maplayer.c
M src/maplexer.c
M src/maplexer.l
M src/mapogcsld.cpp
M src/mapserver.h
R src/mapuvraster.c
Log Message:
Merge pull request #7135 from rouault/rasterlabel
Add CONNECTIONTYPE RASTERLABEL (RFC 139)
Compare: https://github.com/MapServer/MapServer/compare/5d7fbf726715...96e8df8cf1ea
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits
