Branch: refs/heads/main
Home: https://github.com/MapServer/MapServer
Commit: eb2d8af158ece5e941d7a8bfdede75a16349c01d
https://github.com/MapServer/MapServer/commit/eb2d8af158ece5e941d7a8bfdede75a16349c01d
Author: Seth G <sethg at geographika.co.uk>
Date: 2026-04-07 (Tue, 07 Apr 2026)
Changed paths:
M appveyor.yml
M msautotest/config/expected/onlineresource_ogcapi_collections.json
M msautotest/config/expected/onlineresource_wfs_getcapabiltities.xml
M msautotest/config/expected/onlineresource_wms_getcapabiltities.xml
M msautotest/config/expected/onlineresource_wms_getcapabiltities_mapfile.xml
M msautotest/misc/expected/wms_cluster_cap.xml
M msautotest/misc/expected/wms_cluster_cap_latestversion.xml
A msautotest/mspython/test_projections.py
A msautotest/wxs/data/tileSG-000-019_3-3.tif
A msautotest/wxs/data/worldcity_53009.geojson
A msautotest/wxs/expected/wcs_custom_projection_42304_coverage100.png
A msautotest/wxs/expected/wcs_custom_projection_42304_coverage111.dat
A msautotest/wxs/expected/wcs_custom_projection_42304_coverage201.png
A msautotest/wxs/expected/wcs_custom_projection_capabilities100.xml
A msautotest/wxs/expected/wcs_custom_projection_capabilities111.xml
A msautotest/wxs/expected/wcs_custom_projection_capabilities201.xml
A msautotest/wxs/expected/wcs_custom_projection_coverage100.png
A msautotest/wxs/expected/wcs_custom_projection_coverage111.dat
A msautotest/wxs/expected/wcs_custom_projection_coverage201.png
A msautotest/wxs/expected/wcs_custom_projection_describe100.xml
A msautotest/wxs/expected/wcs_custom_projection_describe111.xml
A msautotest/wxs/expected/wcs_custom_projection_describe201.xml
A msautotest/wxs/expected/wfs_custom_projection_capabilities100.xml
A msautotest/wxs/expected/wfs_custom_projection_capabilities110.xml
A msautotest/wxs/expected/wfs_custom_projection_capabilities200.xml
A msautotest/wxs/expected/wfs_custom_projection_getfeature100.json
A msautotest/wxs/expected/wfs_custom_projection_getfeature110_42304.json
A msautotest/wxs/expected/wfs_custom_projection_getfeature110_53009.json
A msautotest/wxs/expected/wfs_custom_projection_getfeature200_42304.json
A msautotest/wxs/expected/wfs_custom_projection_getfeature200_53009.json
M msautotest/wxs/expected/wms_custom_projection_not_specified.xml
A msautotest/wxs/wcs_custom_projection.map
A msautotest/wxs/wfs_custom_projection.map
M msautotest/wxs/wms_custom_projection.map
M src/mapfile.c
M src/mapows.cpp
M src/mapproject.c
M src/mapwcs.cpp
M src/mapwfs.cpp
Log Message:
Add support for non-EPSG projections for WCS and WFS protocols (#7457)
* Support AUTH:CODE projections
* Remove duplicate param
* Allow additional authority codes in the wfs_srs list
* Handle custom init files
* Move parameter and make static
* Add back legacy support for urn:EPSG:geographicCRS:CODE
* Tests updated due to new projection handling
* Test updates
* Add new line
* Handle custom projection files and new style proj codes
* EOL fix
* Handle projections in the form urn:ogc:def:crs:ESRI::53009
* Add WCS tests
* Update authorities based on proj.db
* Add projection string tests
* EOL fixes
* Add test data
* Copy custom projection file
* Remove extent
* Add WFS tests
* Update encodings
* Add custom projection tests for WCS
* Remove DATA
* Test fixes
* Switch result to ASCII
* Use backslashes
* Add test for IGNF:ATIGBONNE.BOURD and update IAU_2015
* Appveyor fix
* EOL fix
* Avoid adding + to AUTH:CODE projection strings
* Always assume PROJ_VERSION_MAJOR >= 6
* Use std::string and avoid strlcpy
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
