[mapserver-commits] [MapServer/MapServer] 40624a: size msClipPolygonRect buffer for 3 emitted points...
Naveed noreply at github.com
Mon Aug 3 03:12:52 PDT 2026
  Branch: refs/heads/main
  Home:   https://github.com/MapServer/MapServer
  Commit: 40624a2b48fec104ab252542347eba870fe96717
      https://github.com/MapServer/MapServer/commit/40624a2b48fec104ab252542347eba870fe96717
  Author: Naveed <naveed at bugqore.com>
  Date:   2026-08-03 (Mon, 03 Aug 2026)
  Changed paths:
    A msautotest/misc/clip_polygon_corners.map
    A msautotest/misc/expected/clip_polygon_corners.png
    M src/mapprimitive.cpp
  Log Message:
  size msClipPolygonRect buffer for 3 emitted points per edge (#7577)
* size msClipPolygonRect buffer for 3 emitted points per edge
* add msautotest case for polygon clipping at the rect corners
Two inline rings whose edges cut across the corners of the clip rectangle,
so a single edge emits three points and the clipped rings come out at 14 and
16 points from 6 and 7. Against the previous 2*numpoints allocation this
aborts under ASAN in msDrawShape().
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits mailing list
