[mapserver-commits] [MapServer/MapServer] 7f354f: Fix SMOOTHSIA point-shape DoS in CGI query path (G...
Zhen Yan
noreply at github.com
Mon Aug 3 06:50:13 PDT 2026
Branch: refs/heads/main
Home: https://github.com/MapServer/MapServer
Commit: 7f354ff84a53dd6f535b3aa35459db9319a265fd
https://github.com/MapServer/MapServer/commit/7f354ff84a53dd6f535b3aa35459db9319a265fd
Author: Zhen Yan <89853352+sdjasj at users.noreply.github.com>
Date: 2026-08-03 (Mon, 03 Aug 2026)
Changed paths:
M HISTORY.md
A msautotest/query/data/point.geojson
A msautotest/query/expected/smoothsia_point_test001.txt
A msautotest/query/smoothsia_point.map
M src/mapsmoothing.c
Log Message:
Fix SMOOTHSIA point-shape DoS in CGI query path (GHSA-33h3-f4q2-pq5q) (#7576)
An unauthenticated denial of service was possible in the CGI query path
(mode=ITEMNQUERY / ITEMQUERY). The qstring expression exposes
SMOOTHSIA([shape], ss, si); msSmoothShapeSIA() derived the per-line
smoothing window size without guarding the single-point case. For a
point feature, numpoints == 1 makes ws collapse to 0 and then to -1,
which is widened to a huge size_t in initLineWindow()'s first
allocation. msSmallMalloc() cannot satisfy it, prints an out-of-memory
message and calls exit(1), killing the worker on every request.
Fixes:
- msSmoothShapeSIA(): skip lines with fewer than 3 points (copied
verbatim, since they cannot be smoothed) and clamp the derived window
size to a positive odd number.
- initLineWindow(): defensively clamp a non-positive size to 1 so a
future caller cannot re-introduce the huge-allocation crash.
Adds an msautotest regression test (query/smoothsia_point.map) that runs
SMOOTHSIA on a point layer via an itemnquery qstring and confirms the
worker no longer terminates.
Co-authored-by: 秦至 <yz534720 at antgroup.com>
Co-authored-by: Jeff McKenna <jmckenna at gatewaygeomatics.com>
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits
