[mapserver-commits] [MapServer/MapServer] 244b6b: Fix WCS 2.0 GetCoverage DoS from non-positive RESO...
github-actions[bot]
noreply at github.com
Mon Aug 3 13:40:46 PDT 2026
Branch: refs/heads/branch-8-6
Home: https://github.com/MapServer/MapServer
Commit: 244b6b17e57b924681e0eb71a55d0eb6e657b091
https://github.com/MapServer/MapServer/commit/244b6b17e57b924681e0eb71a55d0eb6e657b091
Author: github-actions[bot] <41898282+github-actions[bot]@users.noreply.github.com>
Date: 2026-08-03 (Mon, 03 Aug 2026)
Changed paths:
A msautotest/wxs/expected/wcs_20_exception_neg_resolution.xml
A msautotest/wxs/expected/wcs_20_exception_zero_resolution.xml
M msautotest/wxs/wcs_simple.map
M src/mapwcs20.cpp
Log Message:
Fix WCS 2.0 GetCoverage DoS from non-positive RESOLUTION (GHSA-6jr5-rc9c-p3cj) (#7589)
An unauthenticated, remotely reachable denial-of-service vulnerability
exists in MapServer's WCS 2.0 GetCoverage path. The parser accepts any
RESOLUTION value that parses as a double — including negative, zero, and
nan — without a > 0 / finiteness check. The resulting negative image
dimensions are then cast to size_t (huge value) inside
msSmallMalloc()/msSmallCalloc(). Allocation fails, and MapServer's
"safe" allocator terminates the process via exit(1). A single crafted
request kills the handling CGI/FastCGI worker.
Fix:
1. msWCSParseResolutionString20(): After parsing, reject non-finite
values and values <= 0 with InvalidParameterValue. This mirrors the
existing validation in msWCSParseScaleString20() which already
rejects scale <= 0.
2. msWCSGetCoverage20(): Add a defensive guard that rejects width <= 0
or height <= 0 before the existing MAXSIZE check. This catches any
edge case where a non-positive dimension reaches this point.
Tests added in msautotest/wxs/wcs_simple.map:
- Negative RESOLUTION → InvalidParameterValue (was exit(1))
- Zero RESOLUTION → InvalidParameterValue (was raw alloc error)
Co-authored-by: 秦至 <yz534720 at antgroup.com>
Co-authored-by: Jeff McKenna <jmckenna at gatewaygeomatics.com>
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits
