[mapserver-commits] [MapServer/MapServer] 842039: mapcairo.c: revert to svg_handle_render_cairo() (f...
Jeff McKenna
noreply at github.com
Tue Aug 11 04:38:11 PDT 2026
Branch: refs/heads/backport-7583-to-branch-8-6
Home: https://github.com/MapServer/MapServer
Commit: 842039a05077a7dd8786051f051142f0b1fdd192
https://github.com/MapServer/MapServer/commit/842039a05077a7dd8786051f051142f0b1fdd192
Author: Johannes Eberenz <johannes.eberenz at alliander.com>
Date: 2026-08-11 (Tue, 11 Aug 2026)
Changed paths:
M src/mapcairo.c
Log Message:
mapcairo.c: revert to svg_handle_render_cairo() (fixes: #7430)
Since 8.6, rsvg_handle_render_cairo() (marked as depriceated) was replaced with the newer rsvg_handle_render_document(), however this caused scaling issues (#7430). This PR implements a simple workaround by reverting back to the legacy function, solving the issues.
Commit: 58e503d351c5012ac626284abc98f71d911f1906
https://github.com/MapServer/MapServer/commit/58e503d351c5012ac626284abc98f71d911f1906
Changed paths:
M src/mapcairo.c
Log Message:
fix svg scaling by using rsvg_handle_render_document without cairo_scale
Commit: 84cafdc9fb3afa3552814031ec722e0f93b055cf
https://github.com/MapServer/MapServer/commit/84cafdc9fb3afa3552814031ec722e0f93b055cf
Changed paths:
M msautotest/sld/expected/map_linemark.png
Log Message:
correctly rendered test result
Commit: 91f552a6be64a0c81aa950e7d329117168db3066
https://github.com/MapServer/MapServer/commit/91f552a6be64a0c81aa950e7d329117168db3066
Changed paths:
A msautotest/wxs/expected/point_symbol_identification_anchor copy.png
M msautotest/wxs/point_symbol_identification.map
Log Message:
update test coordinates for correctly rendeted SVG
Commit: 71943461c4bbc7b4b0c7256eb522ffa0bb718a0b
https://github.com/MapServer/MapServer/commit/71943461c4bbc7b4b0c7256eb522ffa0bb718a0b
Changed paths:
R msautotest/wxs/expected/point_symbol_identification_anchor copy.png
M msautotest/wxs/expected/point_symbol_identification_anchor.png
M src/mapcairo.c
Log Message:
use symbol size for rsvg_handle_render_document and check vor librscg version
This allows cairo and older rsvgr rendering with scale_cairo>
Also fixed incorrect test png file name
Commit: d1309757bd92ca17fb784bfe715e58251ec5dfaf
https://github.com/MapServer/MapServer/commit/d1309757bd92ca17fb784bfe715e58251ec5dfaf
Author: Jeff McKenna <jmckenna at gatewaygeomatics.com>
Changed paths:
M msautotest/renderers/expected/line_marker_svg.png
M msautotest/renderers/expected/point_svg.png
M msautotest/sld/expected/sld_linemark.png
M msautotest/sld/expected/sld_url_linemark.png
M msautotest/wxs/expected/wms_get_map_symbol_ext_svg_sld.png
Log Message:
update expected results
Compare: https://github.com/MapServer/MapServer/compare/842039a05077%5E...d1309757bd92
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits
