[mapserver-commits] [MapServer/MapServer] fb438a: [Backport branch-8-6] mapcairo.c: avoid double sca...
github-actions[bot] noreply at github.com
Wed Aug 12 02:30:08 PDT 2026
  Branch: refs/heads/branch-8-6
  Home:   https://github.com/MapServer/MapServer
  Commit: fb438a846e806b6ca73334480d9fcf30ff8f8d7e
      https://github.com/MapServer/MapServer/commit/fb438a846e806b6ca73334480d9fcf30ff8f8d7e
  Author: github-actions[bot] <41898282+github-actions[bot]@users.noreply.github.com>
  Date:   2026-08-12 (Wed, 12 Aug 2026)
  Changed paths:
    M msautotest/renderers/expected/line_marker_svg.png
    M msautotest/renderers/expected/point_svg.png
    M msautotest/sld/expected/map_linemark.png
    M msautotest/sld/expected/sld_linemark.png
    M msautotest/sld/expected/sld_url_linemark.png
    M msautotest/wxs/expected/point_symbol_identification_anchor.png
    M msautotest/wxs/expected/wms_get_map_symbol_ext_svg_sld.png
    M msautotest/wxs/point_symbol_identification.map
    M src/mapcairo.c
  Log Message:
  [Backport branch-8-6] mapcairo.c: avoid double scaling of SVG symbols (fixes: #7430) (#7595)
* mapcairo.c: revert to svg_handle_render_cairo() (fixes: #7430)
Since 8.6, rsvg_handle_render_cairo() (marked as depriceated) was replaced with the newer rsvg_handle_render_document(), however this caused scaling issues (#7430). This PR implements a simple workaround by reverting back to the legacy function, solving the issues.
* fix svg scaling by using rsvg_handle_render_document without cairo_scale
* correctly rendered test result
* update test coordinates for correctly rendeted SVG
* use symbol size for rsvg_handle_render_document and check vor librscg version
This allows cairo and older rsvgr rendering with scale_cairo>
Also fixed incorrect test png file name
* update expected results
Co-authored-by: Johannes Eberenz <johannes.eberenz at alliander.com>
Co-authored-by: Jeff McKenna <jmckenna at gatewaygeomatics.com>
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits mailing list
