[mapserver-commits] [MapServer/MapServer] 6ab392: fix heap out-of-bounds write in interpolation laye...
Kaixuan Li
noreply at github.com
Thu Aug 27 06:10:23 PDT 2026
Branch: refs/heads/backport-7602-to-branch-8-6
Home: https://github.com/MapServer/MapServer
Commit: 6ab3929315640ef8c986ed3f3b2b58fdcdf6e5e0
https://github.com/MapServer/MapServer/commit/6ab3929315640ef8c986ed3f3b2b58fdcdf6e5e0
Author: MarkLee131 <kaixuan.li at ntu.edu.sg>
Date: 2026-08-27 (Thu, 27 Aug 2026)
Changed paths:
A msautotest/gdal/expected/idw_oob.png
M msautotest/gdal/idw.map
M src/interpolation.c
Log Message:
fix heap out-of-bounds write in interpolation layers (GHSA-59gr-4vvx-5f56)
msInterpolationDataset() sized the xyz_values buffer by the output pixel
count (WIDTH*HEIGHT) but wrote 3 floats per in-extent sample vertex, and the
vertex count is not bounded by the pixel count. An unauthenticated WMS GetMap
over an IDW/KERNELDENSITY/KRIGING layer with a grid smaller than the sample
count overflowed the heap. Grow the buffer as needed so every sample is
stored within the allocation.
Adds a regression test as an extra request in the existing
msautotest/gdal/idw.map (1000x2 grid over data/pnts.shp): it aborts under
AddressSanitizer before the fix and produces a valid image after it.
Commit: c35332b886d1d3339607c4fd596ff649169ee164
https://github.com/MapServer/MapServer/commit/c35332b886d1d3339607c4fd596ff649169ee164
Changed paths:
Log Message:
interpolation: guard xyz_values capacity against zero
Address review feedback: keep the xyz_values capacity non-zero so the
doubling growth loop always makes progress, even in the theoretical case of a
zero-sized image where im_width*im_height would be 0.
Compare: https://github.com/MapServer/MapServer/compare/6ab392931564%5E...c35332b886d1
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits
