[mapserver-commits] [MapServer/MapServer] 57a5d5: WMS OpenLayers output: escape angle brackets in ma...
Even Rouault
noreply at github.com
Tue Jul 7 10:12:31 PDT 2026
Branch: refs/heads/branch-8-6
Home: https://github.com/MapServer/MapServer
Commit: 57a5d592a4270137c20f33459d59d370b5374426
https://github.com/MapServer/MapServer/commit/57a5d592a4270137c20f33459d59d370b5374426
Author: MarkLee131 <kaixuan.li at ntu.edu.sg>
Date: 2026-07-07 (Tue, 07 Jul 2026)
Changed paths:
M msautotest/pymod/mstestlib.py
A msautotest/wxs/expected/wms_openlayers_xss.txt
A msautotest/wxs/wms_openlayers_xss.map
M src/maptemplate.c
Log Message:
WMS OpenLayers output: escape angle brackets in mapserv_onlineresource
The GHSA-xqj6-vjqr-33vv fix only escaped the JS quote, so a literal
</script> in a forwarded host/proto header still closed the <script>
block. Encode the angle brackets as their JavaScript unicode escapes
so the value stays a JS string and cannot break out of the element.
Add a msautotest case (wxs/wms_openlayers_xss) and make the [ENV ...]
test directive repeatable so it can set the request headers it needs.
Commit: 93d58759132de27a22e3476d21f1e55b5ffbf124
https://github.com/MapServer/MapServer/commit/93d58759132de27a22e3476d21f1e55b5ffbf124
Author: Even Rouault <even.rouault at spatialys.com>
Changed paths:
M src/maptemplate.c
Log Message:
Merge pull request #7554 from MapServer/backport-7544-to-branch-8-6
[Backport branch-8-6] WMS OpenLayers output: escape angle brackets in mapserv_onlineresource
Compare: https://github.com/MapServer/MapServer/compare/465e82fe0864...93d58759132d
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits
