[mapserver-commits] [MapServer/MapServer] 548180: [Backport branch-8-6] mapcontext: fix out-of-bound...
github-actions[bot]
noreply at github.com
Sun Sep 6 09:58:35 PDT 2026
Branch: refs/heads/branch-8-6
Home: https://github.com/MapServer/MapServer
Commit: 548180af3063ceaa74004e8394c82772d5fa7c2a
https://github.com/MapServer/MapServer/commit/548180af3063ceaa74004e8394c82772d5fa7c2a
Author: github-actions[bot] <41898282+github-actions[bot]@users.noreply.github.com>
Date: 2026-09-06 (Sun, 06 Sep 2026)
Changed paths:
A msautotest/wxs/expected/ows_context_bad_srs_caps.xml
M msautotest/wxs/ows_context.map
A msautotest/wxs/ows_context_bad_srs.xml
M src/mapcontext.c
Log Message:
[Backport branch-8-6] mapcontext: fix out-of-bounds read on short BoundingBox SRS (#7644)
* mapcontext: fix out-of-bounds read on short BoundingBox SRS
The General.BoundingBox.SRS value from a Web Map Context document was
only checked against the "AUTO:" prefix before stripping 5 bytes with
pszValue + 5, so an SRS shorter than the assumed "EPSG:" prefix read
past the end of the value. Strip only when the value starts with
"EPSG:", otherwise pass it through unchanged.
* update formatting
Co-authored-by: Naveed <naveed at bugqore.com>
Co-authored-by: Jeff McKenna <jmckenna at gatewaygeomatics.com>
To unsubscribe from these emails, change your notification settings at https://github.com/MapServer/MapServer/settings/notifications
More information about the MapServer-commits
