[mapserver-dev] Compile problem
Daniel Morissette
morissette at dmsolutions.ca
Tue Aug 27 18:02:28 EDT 2002
Hummm... probably a related problem, but different manifestation...
Can you please Email me the output of 'perl -V' on your system... yes, I
really meant 'perl -V' ... that's a hack used by the configure script.
Daniel
Ken Kyler wrote:
> > > cc: undef: No such file or directory
> > I suspect that it's this mapscript Makefile problem striking again...
> > you could take out the 'undef' in the CC of CFLAGS variable definition
> > in mapscript/php3/Makefile.
> > The other option is to download the 3.6.2 source from
> > http://www2.dmsolutions.ca/mapserver/dl/ in which this problem should be
> > fixed already. This web server is currently down but it will be back up
> > first thing tomorrow morning.
> I downloaded 3.6.2 and got the same error
> cd mapscript/php3; make; cd ../..
> cc
> ef -I. -I.. -DPIC -fpic -O2 -Wall -DCOMPILE_DL=1 -DPHP4 -DUSE_EPPL -DU
> SE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIM
> AGEGIFPTR -DUSE_JPEG -I/usr/local/src/mapserver-3.6.2 -I/usr/local/
> include -I/usr/local/include -I/usr/ports/www/mod_php4/work/php-4.2.2 -I/usr
> /ports/www/mod_php4/work/php-4.2.2/dl -I/usr/ports/www/mod_php4/work/php-4.2
> .2/main -I/usr/ports/www/mod_php4/work/php-4.2.2/Zend -I/usr/ports/www/mod_
> php4/work/php-4.2.2/include -I/usr/ports/www/mod_php4/work/php-4.2.2/TSRM -
> c php_mapscript_util.c
> I then changed the mapscript/php3/Makefile to...
> CC = cc -I. -I.. -DPIC -fpic
> and got
> cc -Wl -Wl -o php_mapscript.so php_mapscript_util.o php_mapscript.o
> mapscript_i.o -R/usr/local/lib -R/usr/local/src/mapserver-3.6.2 -L/usr/local
> /src/mapserver-3.6.2 -lmap -L/usr/local/lib -ljpeg -L/usr/local/lib
> -lfreetype -L/usr/local/lib -lpng -lz -L/usr/local/lib -lgd -L/usr/local/l
> ib -ljpeg -L/usr/local/lib -lfreetype -L/usr/local/lib -lpng -lz -L/usr/loca
> l/lib -ljpeg -lm
> /usr/libexec/elf/ld: warning: libpng.so.4, needed by
> /usr/local/lib/libgd.so, may conflict with libpng.so.5
> php_mapscript_util.o: In function `_phpms_report_mapserver_error':
> php_mapscript_util.o(.text+0x33): undefined reference to `zend_error'
> plus a long set of other "undefined reference to" errors
> Other thoughts?
> again, this is a FreeBSD 4.5-STABLE box
> Ken
