[mapserver-dev] Debugging a CGI in MSVC
Pradeep
pradeepkumar at infotech.stph.net
Mon Nov 18 23:32:48 EST 2002
Greetings
I have the mapserver sources running on windows, compiled using the
MSVC compiler,I wish to debug it, and follow the code flow setting some
break points in the code, as far as now I was unsuccessful trying to debug
the CGI exe, I have used __asm {int 3}; statement to programatically set
break points in the code, but still the VC debugger fails to launch. In
essense can any user working in windows environment tell me How to debug a
CGI application?
Thanks for your time
Pradeep.
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20021119/c4d304ac/attachment.html
