[mapserver-dev] msCleanup()
Tue Nov 19 15:45:18 EST 2002
Folks,
I have introduced an msCleanup() function which I intend to cleanup
dynamically allocated resources that are not tied to a map instance.  It
is to be called by applications as the terminate in situations where we want
to do memory leak testing.  I have added it to shp2img, so I can use shp2img
for testing for memory leaks.
Currently msCleanup() unloads datum shift grids (from PROJ) and unregisters
GDAL drivers.
Memory leak testing with valgrid shows things are pretty good.  There is a
chunk of memory allocated by the parser that isn't recovered, but I don't
want to try and fix it since it is non-recurring (I think), and might be
different depending on what yacc is used to generate the auto-generated
files.
Best regards,
