[Mapserver-dev] mapserver grid utility
Yewondwossen Assefa assefa at dmsolutions.ca
Mon Apr 21 10:37:03 EDT 2003
Hi There,
 I would like to enquire about the status of the grid functionnality
 inside mapserver. Are there more development to come concerning this ?
 I have managed to generate a grid using what is alredy available. I am
 missing some infos on a couple of parameters (MINSUBDIVIDE,
MAXSUBDIVIDE). Is there
 a doc attached to this functionnality ?
 I also encoutered a problem when saving a map file that contains a GRID
element : the
 original map contains a layer where the GRID parameters are specified
under the Layer
tag :
  Layer
    CLASS
    END
    GRID
    END
 When the map is saved, the GRID element is written under a FEATURE
element, causing a
problem at read time :
   Layer
    CLASS
    END
    FEATURE
      GRID
       END
   END
Thanks
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
