[Mapserver-dev] Labeling Question
woodbri at swoodbridge.com
Sat Aug 30 09:42:30 EDT 2003
Hi all,
I have been thinking about labelling and have a question about
mapserver's strategy or lack there of :)
It seems to me that the when constructing a mapfile that the layers
are put down like polygon areas, then minor line art, then major line
art, then point objects BUT when labelling the map you want your
labels to be generated in the reverse priority ie: label points
first, then major line art, them minor line art, then polygons, etc.
So in the mapfile you can either label objects when you lay them down
or you can take a second pass through all your layers to change the
order of labelling. The label as you go is faster but your labels are
prioritized backwards or you have to scan your files twice. An
lastly, labels are added to the cache in the same basic order as they
are found in the data sets which may or may not make sense.
Assuming that I got this right so far ... probably a big wrong
assumption on my part :)
Wouldn't is make more sense to construct a list of potential labels
and then load the list backwards into the label cache to deal with
collisions. This would cost a little more in memory, but I think it
would faster and and cutdown on the number of layers and give better
results for probably 90+% of the cases. You could still have
ANNOTATION layers for more control or set up other additional
strategies for prioritizing important labels.
A related idea would be to be able to give labels attributes like
LEVEL=n and FORCE=0|1 these would have the effect of allowing you to
set the force labels on on a label by label or expression and level
would allow you to class labels into layers the get added to the
cache based on their LEVELs.
For example, I would like to label polygons with a muted color in the
background and force those labels on, but I don't want them to bump
other labels out of the cache. So I might say
LEVEL=0
FORCE=1
CACHE=0
which would cause these labels to be drawn first (LEVEL=0) and they
would be forced to be drawn and they would not be added to the cache
so other labels might be drawn later over them. I might make LEVEL=-1
to mean that the label is drawn at the time the layer is drawn.
Thoughts, comments, and flames welcome.
-Steve W.
