[Mapserver-dev] bug in mapswf.c (msDrawLabelCacheSWF)?
Steve Spicklemire
steve at spvi.com
Tue Dec 2 23:13:41 EST 2003
Hi Yewondwossen,
Yes.. please send me your patch.. and I'll test it!
thanks,
-steve
On Dec 2, 2003, at 4:55 PM, Yewondwossen Assefa wrote:
> Hi There,
> Thanks for pointing this out.
> I have done the modifications to the source code to avoid the problem.
> Although the changes you did should avoid the crash, there was a
> potential error when assigning image->img.swf->nCurrentMovie =
> cachePtr->layerindex since the movie index and the layer index are not
> in sync. The crash happened for layerindex > nLayerMovies but the
> assignment could also be wrong without a crash.
> If you are willing to do the tests please contact me personally and I
> will send you the modifications before commiting the code. If not I
> will enter a bug and commit the code when I will do proper testing on
> my side.
> Late
> Steve Spicklemire wrote:
>> Hi (again) Mapserver folks,
>> I have a map where msDrawLabelCacheSWF segfaults mapserver when
>> OUTPUT_MOVIE=MULTIPLE. The problem is that if the last layer is not
>> drawn, drawMap still tries to cache labels on that layer, and
>> (mistakenly) tries to access the movie for that layer, which
>> immediately segfaults since there is no movie for that layer
>> (drawlayer never calls startlayer if the layer isn't visible).
>> Anyway... this patch stops the crashing for me:
>> Index: mapswf.c
>> RCS file: /data2/cvsroot/mapserver/mapswf.c,v
>> retrieving revision 1.31
>> diff -C3 -r1.31 mapswf.c
>> *** mapswf.c 16 Jul 2003 16:44:58 -0000 1.31
>> --- mapswf.c 2 Dec 2003 20:53:18 -0000
>> *** 2119,2128 ****
>> /* set the current layer so the label will be drawn in the
>> /* using the correct SWF handle.
>> ! image->img.swf->nCurrentMovie = cachePtr->layerindex;
>> ! //msImageStartLayerSWF(map, layerPtr, image);
>> ! image->img.swf->nCurrentLayerIdx = cachePtr->layerindex;
>> /* at this point the layer (at the shape level is closed). So
>> /* we will open it if necessary.
>> --- 2119,2134 ----
>> ! if (cachePtr->layerindex >= image->img.swf->nLayerMovies) {
>> ! continue;
>> I've not seen any trouble with it so far..
>> -steve
>> Mapserver-dev mailing list
>> Mapserver-dev at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
