[Mapserver-dev] suggestion needed for using mapserver as a generic browser of 2000+ layers of data?
Sean Gillies sgillies at frii.com
Mon Dec 8 12:34:26 EST 2003
On Monday, December 8, 2003, at 10:15  AM, Stephen Clark wrote:
> Hi all,
> I am working on a project to dynamically display over  2000+ layers of
> data
> (point, polygons, raster,  etc.) and am interested in finding a way to
> get
> past the HARD CODED number of layers in mapserver / mapscript *.map
> files.
> OR maybe there is some
> short term solution for using PHP mapscript to dynamically generate
> *.map
> files from a list of map files each specified by a type (e.g., raster
> layers, polygon layers, )
> Any thoughts?
> Also, is there plans to have the HARD CODED number of layers in
> mapserver
> bug fixed in the 4.1 release?
> thanks,
> Stephen
Stephen,
I have entered two related feature enhancements to Bugzilla that may
interest you:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=357
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=358
These are not about increasing the number of possible layers or
making the number of layers dynamically extendable, but are about
a new framework that makes it possible to accomplish your 2000+
layer problem.
I'm proposing that layers be objects that can: 1) exist outside
of a map, 2) be instantiated from a map file "fragment".  In my
use cases, what you would do is either
1) keep map file fragments which completely define a layer as
text/varchar in your favorite RDBMS, allow a user to select
layers, instantiate them from the fragments, then insert the
layer object into a map object for rendering and output.
or 2) store layer objects in an persistent object database
and insert them into a map object as needed.
My proposal primarily concerns MapScript (all flavors) but some
have seen many useful applications for the mapserv app itself.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
