[Mapserver-dev] bug in mapswf.c (msDrawLabelCacheSWF)?
Steve Spicklemire
steve at spvi.com
Tue Dec 9 06:58:55 EST 2003
Hi Yewondwossen,
Here's another patch to try. I was getting text cached on the wrong
layers.. tracked it down to this:
Index: mapswf.c
RCS file: /data2/cvsroot/mapserver/mapswf.c,v
retrieving revision 1.33
diff -a -u -r1.33 mapswf.c
--- mapswf.c 3 Dec 2003 02:03:41 -0000 1.33
+++ mapswf.c 9 Dec 2003 11:56:18 -0000
@@ -2069,7 +2069,7 @@
for (i=0; i<nSize; i++)
- if (panIndex[i] = nIndex)
+ if (panIndex[i] == nIndex)
nIndice = i;
break;
On Dec 3, 2003, at 10:22 AM, Yewondwossen Assefa wrote:
> Hi There,
> I have commited mapswf.c and map.h with the fix and you can get them
> from CVS. Let me know how it goes.
> Later,
> Steve Spicklemire wrote:
>> Hi Yewondwossen,
>> Yes.. please send me your patch.. and I'll test it!
>> thanks,
>> -steve
>> On Dec 2, 2003, at 4:55 PM, Yewondwossen Assefa wrote:
>>> Hi There,
>>> Thanks for pointing this out.
>>> I have done the modifications to the source code to avoid the
>>> problem.
>>> Although the changes you did should avoid the crash, there was a
>>> potential error when assigning image->img.swf->nCurrentMovie =
>>> cachePtr->layerindex since the movie index and the layer index are
>>> not in sync. The crash happened for layerindex > nLayerMovies but
>>> the assignment could also be wrong without a crash.
>>> If you are willing to do the tests please contact me personally and
>>> I will send you the modifications before commiting the code. If not
>>> I will enter a bug and commit the code when I will do proper
>>> testing on my side.
>>> Late
>>>> Hi (again) Mapserver folks,
>>>> I have a map where msDrawLabelCacheSWF segfaults mapserver when
>>>> OUTPUT_MOVIE=MULTIPLE. The problem is that if the last layer is not
>>>> drawn, drawMap still tries to cache labels on that layer, and
>>>> (mistakenly) tries to access the movie for that layer, which
>>>> immediately segfaults since there is no movie for that layer
>>>> (drawlayer never calls startlayer if the layer isn't visible).
>>>> Anyway... this patch stops the crashing for me:
>>>> Index: mapswf.c
>>>> retrieving revision 1.31
>>>> diff -C3 -r1.31 mapswf.c
>>>> *** mapswf.c 16 Jul 2003 16:44:58 -0000 1.31
>>>> --- mapswf.c 2 Dec 2003 20:53:18 -0000
>>>> *** 2119,2128 ****
>>>> /* set the current layer so the label will be drawn in the
>>>> /* using the correct SWF handle.
>>>> ! image->img.swf->nCurrentMovie = cachePtr->layerindex;
>>>> ! //msImageStartLayerSWF(map, layerPtr, image);
>>>> ! image->img.swf->nCurrentLayerIdx = cachePtr->layerindex;
>>>> /* at this point the layer (at the shape level is closed).
>>>> So */
>>>> /* we will open it if necessary.
>>>> --- 2119,2134 ----
>>>> ! if (cachePtr->layerindex >= image->img.swf->nLayerMovies) {
>>>> ! continue;
>>>> So */
>>>> I've not seen any trouble with it so far..
>>>> -steve
>>>> _______________________________________________
>>>> Mapserver-dev mailing list
>>>> Mapserver-dev at lists.gis.umn.edu
>>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
>>> Assefa Yewondwossen
>>> Software Analyst
>>> Email: assefa at dmsolutions.ca
>>> http://www.dmsolutions.ca/
>>> Phone: (613) 565-5056 (ext 14)
>>> Fax: (613) 565-0925
> Assefa Yewondwossen
> Software Analyst
> Fax: (613) 565-0925
