[Mapserver-dev] Add shape id's in the selection
Chris G. Nicholas
cgn at globexplorer.com
Fri Feb 14 10:18:16 EST 2003
keep in mind that folks like us (GlobeXplorer) generally have a bank of machines front-ending traffic, being fed by a load balancer (such as: http://www.f5.com/f5products/bigip/)
therefore, don't assume that one click to the next hits the same machine...one would want to use an extensible session object something extensible that might have a default implementation in a RAM, but can definitely use a centralized db or nfs area...
Chris Nicholas
GlobeXplorer
-----Original Message-----
From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
Sent: Fri 2/14/2003 6:27 AM
To: Steve Lime
Cc: mapserver-dev
Subject: [Mapserver-dev] Add shape id's in the selection
Hi There,
I was looking into how to keep selected elements between page submits.
What I want is to be able to show the selections (using draw query)
after a page has submitted without doing each time a query. In some
applications, peopole want to do a query and do some panning, zooming
without their query being lost.
I was thinking of adding a couple of utility functions to add shpes
id's to a resultcached used during the query. It will be less costly in
time to use these functions instead of redoing the query every time.
Do You think It is a useful ? Any comments/objections ?
Later,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
