[Mapserver-dev] Graticule support is checked in to CVS...
Administrator
jnovak at novacell.com
Sat Feb 15 22:45:00 EST 2003
And here's the new GRID keyword documentation:
The layer definition
LAYER
NAME "SAMPLE GRID"
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
END
TYPE LINE
STATUS DEFAULT
CLASS
COLOR 0 255 128
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 255 128 89
END
END
FEATURE
GRID
END
END
END
Will generate a graticule with default arc spacing, arc color RGB 0 255
128 and labeled in decimal degrees with color RGB 255 128 89. Labels
will appear at all four of the image edges.
Each arc in the resulting grid is composed of 256 line segments. To
render grid arcs with a different number of segments, use the
MINSUBDIVIDE and MAXSUBDIVIDE keywords. Setting MINSUBDIVIDE ==
MAXSUBDIVIDE will always yield exactly the number of segments specified.
To set the format of the grid labels, specify a printf style format
string after the LABELFORMAT keyword. The default string is "%5.2f".
To get DMS labeling, enter "DDMMSS" as the LABELFORMAT string used by
the GRID, and for DM labeling, specify "DDMM".
The GRID feature
FEATURE
GRID
MINSUBDIVIDE 64
MAXSUBDIVIDE 64
LABELFORMAT "DDMMSS"
END
END
Yields a grid with 64 segments in every arc labeled with degrees,
minutes and seconds.
Other keywords behave similarly:
MININTERVAL and MAXINTERVAL allow a range to be set for grid spacing.
The interval is specified in the coordinate system of the grid. Since
PROJECTION is supported, if your mapserver has PROJ4, the grid may be in
any coordinate system supported by PROJ4, and will be projected into the
coordinate system of the generated image.
MINARCS and MAXARCS are hints to the code that generates grid intervals
regarding when to stop subdividing the range of an axis.
The subdivider will try to honor the range specified, or the min/max id
only one keyword is present.
Please let me know if there are bugs, questions or comments.
Regards,
John Novak
Novacell Technologies
www.novacell.com
