[Mapserver-dev] New msCloneLayerObj() function
Sean Gillies
sgillies at frii.com
Mon Feb 17 14:40:09 EST 2003
On Monday, February 17, 2003, at 11:54 AM, Daniel Morissette wrote:
> Steve,
> We are thinking of adding a new function to mapfile.c (and MapScript)
> to
> initialize a new layer by creating a clone of an existing layer. This
> would allow us to easily make copies of layers inside a single mapObj,
> or to copy layers from one mapObj to another.
> The C function prototype would be:
> int msCloneLayerObj(mapObj *target_map, layerObj *src_layer);
> which would create a new layer inside target_map which is a copy of
> src_layer.
> In PHP MapScript, the function ms_newMapObj() would be extended to take
> an optional second argument that would be the layer to clone:
> layerObj ms_newLayerObj(mapObj target_map [,layerObj layer_to_clone])
> I don't think SWIG allows for optional arguments like we use in PHP, so
> we would have to expose a separate function for msCloneLayerObj() in
> the
> SWIG'd MapScript.
> Is that OK with you? Any suggestions, comments?
> Daniel
Daniel,
There was a request in Bugzilla for a msCopyMap() function that I
accepted as my first contribution to MapServer. I've nearly finished
it and it has what you are looking for.
int msCopyLayer(layerObj *dst, layerObj *src, mapObj *map);
I picked the argument order to resemble memcpy(). The mapObj is
needed as a final argument because the destination layer needs a
pointer to it's parent map. It's intended to copy layers
between maps, but could copy within a map as well.
In mapscript.i, I was planning to extend layerObj with a copy()
function which would be used like this Python example:
map1 = mapObj(mapfile) # contains a layer
lay1 = map1.getlayer(0)
lay2 = layerObj(map1)
lay2 = lay1.copy()
I'm reluctant to commit my code into mapfile.c since there's ~700 lines
(including functions to copy other map objects), so I was thinking
of a new file? mapcopy.c perhaps? I could commit this file to CVS if
you want to take a look.
Speaking of new features -- I've been wishing for functions to remove
layers and classes from mapObjs. I thought I might move on to that
next after finishing the ms*Copy stuff.
cheers,
Sean
Sean Gillies
http://www.frii.com/~sgillies
