[Mapserver-dev] Optimizing msAddLine()
Steve Lime
steve.lime at dnr.state.mn.us
Fri Jan 10 02:02:32 EST 2003
Any comments or can we go ahead and add this? Dan?
>>> David Turover <dturover at student.santarosa.edu> 01/08/03 13:10 PM >>>
On Mon, 6 Jan 2003, Daniel Morissette wrote:
> Steve Lime wrote:
> > Thanks David, lemme (and others?) look through the code and test it
a
> > bit. Certainly looks
> > promising though. Wonder how much affect it has in web use...
> I think the basic idea is great (better than reallocating one item
> at a time), but I'm worried a bit by the overhead in memory usage
> involved in general use of the current solution, especially for things
> like the labelcache that stores shapes for each label.
[snip]
> Anyway, what I wanted to propose is to start with a smaller buffer and
> double the buffer size everytime we realloc, e.g. start with a buffer
of
> 8 lineObj, then realloc to 16, 32, 64, 128, ... ...
[snip]
How does this look?
void msArrayResizeIfFull(void ** arrayPtr, int numItems, int itemSize){
const static int maxArraySegment = 256;
void * newArray;
if(arrayPtr == NULL) return;
/* Set newArray equal to the original array so
** if newArray changes we know that malloc was called on it,
** and that newArray == NULL means malloc failed. */
newArray = *arrayPtr;
if(numItems < maxArraySegment){
switch(numItems){
case 0: /* malloc an initial array */
newArray = calloc(8, itemSize);
break;
case 8: /* Fall through */
case 16: /* Fall through */
case 32: /* Fall through */
case 64: /* Fall through */
case 128:
newArray = calloc(numItems * 2, itemSize);
memcpy(newArray, *arrayPtr, numItems *
itemSize);
break;
default: break;
} else if(numItems % maxArraySegment == 0){
newArray = calloc(numItems + maxArraySegment,itemSize);
memcpy(newArray, *arrayPtr, numItems * itemSize);
if(newArray != *arrayPtr){
if(newArray == NULL)
msSetError(MS_MEMERR, NULL,
"msArrayResizeIfFull()");
else{
msFree(*arrayPtr);
*arrayPtr = newArray;
return;
And msAddLine() becomes:
int msAddLine(shapeObj *p, lineObj *new_line){
lineObj *extended_line;
msArrayResizeIfFull((void **)&p->line, p->numlines,
sizeof(lineObj));
/* Update the polygon information */
extended_line = &p->line[p->numlines];
/* Copy the points to the line array */
extended_line->numpoints = new_line->numpoints;
if((extended_line->point = (pointObj
*)malloc(new_line->numpoints
* sizeof(pointObj))) == NULL) {
msSetError(MS_MEMERR, NULL, "msAddLine()");
return(-1);
memcpy(extended_line->point, new_line->point,
new_line->numpoints
* sizeof(pointObj));
p->numlines++;
return(0);
This hasn't been well tested (it runs here, but I haven't tried to hit
every branch to see what happens).
BTW: I glanced at maplabel.c and it appears the labelcache is already
expanding by increments of 10, so that shouldn't be a problem.
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
