On Fri, 10 Jan 2003, Steve Lime wrote: > Any comments or can we go ahead and add this? Dan? It still needs work. The generalized array expansion function does a poor job of error handling -- if the malloc fails, then the calling function will try adding to memory past the end of the original array.
