[Mapserver-dev] libstdc++ and mapogr.cpp
Jeremy Gwinnup
jgwinnup at mbvlab.wpafb.af.mil
Fri Jan 17 09:16:10 EST 2003
Hi all,
Been experimenting with the build process of libmap.a and the utility
binaries - I noticed that mapogr.cpp is the only c++ file in the library
- Is this because there is no C-based OGR link?
It was problematic to build the utilities, since the library looks for a
__gcc_personality symbol, which is n libstdc++
Linking libstdc++ to the binaries solved the problem, as suggested by a
message in the dev-list archives. There seems to be no ill effects of
linking the c++ library in, but I do not enable OGR in my local builds.
My platform:
linux, gcc-3.2
Thanks
-Jeremy
Jeremy Gwinnup <jgwinnup at mbvlab.wpafb.af.mil>
Veridian Engineering
