[Mapserver-dev] file handle leakage in mapswf.c?
Steve Spicklemire
steve at spvi.com
Wed Jul 16 09:44:22 EDT 2003
Hi Mapserver developers..
First, I want to thank you for a fantastic product. In a very short
period of time, I've moved the mapping code of a complex system to
mapscript. We're developing a sort of property/inventory management
system with Zope and flash. We needed maps to make it possible to view
the system in a graphical way. I started with ming alone, but happily
someone pointed out Mapserver, and I found that with Mapserver, and
PostGIS I could do everything I needed to. The only problem was that
scaling, rotating, and sometimes even presentation of fonts wasn't
working. I scoured the mailing lists.. and fiddled around with
variations on mapfiles for several days. Yesterday, I decided that I
needed to dig in to the code with the debugger and find out what was
really happening. It seems that mapswf.c allocates a file handle to
read a font file every time it draws text! I had a *lot* of labels on
my maps, and my process was running out of file handles. Unfortunately
this was silently ignored, and the result was simply no output! (By the
time the code got around to trying to *write* anything, all the file
handles were consumed by attempts to load the font from the filesystem).
Anyway.. my quick-fix is to simply close the font file every time it's
read. Probably some sort of font-cache would make more sense. (I think
that ming may already *have* a font cache.. I'll look into what it
would take to find out.)
Here are my patches to mapswf.c...
-steve
diff -C3 -r1.29 mapswf.c
*** mapswf.c 11 Jun 2003 17:54:42 -0000 1.29
--- mapswf.c 16 Jul 2003 13:31:12 -0000
*** 1563,1580 ****
if (!string || !pszFontFile || !psColor)
return NULL;
! oFont = loadSWFFontFromFile(fopen(pszFontFile, "rb"));
! if (oFont)
! oText = newSWFText();
! SWFText_setFont(oText, oFont);
! SWFText_moveTo(oText, (float)nX, (float)nY);
! SWFText_setColor(oText, (byte)psColor->red,
(byte)psColor->green, (byte)psColor->blue,
! 0xff);
! SWFText_setHeight(oText, (float)dfSize);
! SWFText_addString(oText, string, NULL);
! return oText;
return NULL;
--- 1563,1585 ----
return NULL;
! FILE *f = fopen(pszFontFile, "rb");
! if (f) {
! oFont = loadSWFFontFromFile(f);
! if (oFont)
! fclose(f);
! 0xff);
! return oText;
return NULL;
*** 1896,1902 ****
// char *error=NULL, *font=NULL;
// int bbox[8];
- // double angle_radians = MS_DEG_TO_RAD*label->angle;
size = label->size*scalefactor;
--- 1901,1906 ----
*** 1953,1963 ****
return(-1);
! oText = DrawText(string, x, y, msBuildPath(szPath,
fontset->filename, font), size, &sColor);
if (oText)
//nTmp = image->img.swf->nCurrentMovie;
! SWFMovie_add(GetCurrentMovie(map, image), oText);
return 0;
--- 1957,1970 ----
return(-1);
! oText = DrawText(string, 0, 0, msBuildPath(szPath,
if (oText)
+ SWFDisplayItem i;
! i = SWFMovie_add(GetCurrentMovie(map, image), oText);
! SWFDisplayItem_moveTo(i, x, y);
! SWFDisplayItem_rotate(i, (float)label->angle);
return 0;
*** 1997,2005 ****
return(-1);
! oFont = loadSWFFontFromFile(fopen(msBuildPath(szPath,
fontset->filename, font), "rb"));
if (oFont)
//SWFText_addString(oText, string, NULL);
--- 2004,2014 ----
return(-1);
! FILE *f = fopen(msBuildPath(szPath, fontset->filename, font),
"rb");
if (oFont)
+ fclose(f);
*** 2543,2548 ****
--- 2552,2558 ----
int nLength;
int iPointPos;
int iSlashPos;
+ int iSaveResult;
char szAction[200];
SWFAction oAction;
mapObj *map = NULL;
*** 2558,2565 ****
"OUTPUT_MOVIE",""),
"MULTIPLE") != 0)
! SWFMovie_save(image->img.swf->sMainMovie, filename);
return(MS_SUCCESS);
--- 2568,2579 ----
"OUTPUT_MOVIE",""),
"MULTIPLE") != 0)
! iSaveResult = SWFMovie_save(image->img.swf->sMainMovie,
filename);
! if (!iSaveResult) {
return(MS_SUCCESS);
+ }else{
+ return(MS_FAILURE);
