[Mapserver-dev] file handle leakage in mapswf.c?
Steve Spicklemire steve at spvi.com
Wed Jul 16 12:11:53 EDT 2003
Thanks Yewondwossen,
On Wednesday, July 16, 2003, at 11:08  AM, Yewondwossen Assefa wrote:
> Hi There,
> I have applied the patches to mapswf.c (r1.30). Thnaks a lot.
> There still seems to be an issue when rendering labels with angles.
> Does this work properly for you ? You can contact me off the list on
> this issue if It works for you. If not I will enter a bug in mapserver
> on that.
Hmm.. well.. before my changes, it didn't work at all. After I made my
changes.. it's working for me. What does it do on your system?
thanks,
-steve
> Later,
> Steve Spicklemire wrote:
>> Hi Mapserver developers..
>> First, I want to thank you for a fantastic product. In a very short
>> period of time, I've moved the mapping code of a complex system to
>> mapscript. We're developing a sort of property/inventory management
>> system with Zope and flash. We needed maps to make it possible to
>> view the system in a graphical way. I started with ming alone, but
>> happily someone pointed out Mapserver, and I found that with
>> Mapserver, and PostGIS I could do everything I needed to. The only
>> problem was that scaling, rotating, and sometimes even presentation
>> of fonts wasn't working. I scoured the mailing lists.. and fiddled
>> around with variations on mapfiles for several days. Yesterday, I
>> decided that I needed to dig in to the code with the debugger and
>> find out what was really happening. It seems that mapswf.c allocates
>> a file handle to read a font file every time it draws text! I had a
>> *lot* of labels on my maps, and my process was running out of file
>> handles. Unfortunately this was silently ignored, and the result was
>> simply no output! (By the time the code got around to trying to
>> *write* anything, all the file handles were consumed by attempts to
>> load the font from the filesystem).
>> Anyway.. my quick-fix is to simply close the font file every time
>> it's read. Probably some sort of font-cache would make more sense. (I
>> think that ming may already *have* a font cache.. I'll look into what
>> it would take to find out.)
>> Here are my patches to mapswf.c...
>> -steve
>> diff -C3 -r1.29 mapswf.c
>> *** mapswf.c    11 Jun 2003 17:54:42 -0000      1.29
>> --- mapswf.c    16 Jul 2003 13:31:12 -0000
>> *** 1563,1580 ****
>>       if (!string || !pszFontFile || !psColor)
>>           return NULL;
>> !     oFont  = loadSWFFontFromFile(fopen(pszFontFile, "rb"));
>> !     if (oFont)
>> !         oText = newSWFText();
>> !         SWFText_setFont(oText, oFont);
>> !         SWFText_moveTo(oText, (float)nX, (float)nY);
>> !         SWFText_setColor(oText, (byte)psColor->red,
>> (byte)psColor->green, (byte)psColor->blue,
>> !                          0xff);
>> !         SWFText_setHeight(oText, (float)dfSize);
>> !         SWFText_addString(oText, string, NULL);
>> !         return oText;
>>       return NULL;
>> --- 1563,1585 ----
>>           return NULL;
>> !     FILE *f = fopen(pszFontFile, "rb");
>> !     if (f) {
>> !       oFont  = loadSWFFontFromFile(f);
>> !       if (oFont)
>> !         fclose(f);
>> !                          0xff);
>> !         return oText;
>>       return NULL;
>> *** 1896,1902 ****
>>   //    char *error=NULL, *font=NULL;
>>   //    int bbox[8];
>> - //    double angle_radians = MS_DEG_TO_RAD*label->angle;
>>       size = label->size*scalefactor;
>> --- 1901,1906 ----
>> *** 1953,1963 ****
>>         return(-1);
>> !     oText = DrawText(string, x, y, msBuildPath(szPath,
>> fontset->filename, font), size, &sColor);
>>       if (oText)
>>           //nTmp = image->img.swf->nCurrentMovie;
>> !         SWFMovie_add(GetCurrentMovie(map, image), oText);
>>       return 0;
>> --- 1957,1970 ----
>>         return(-1);
>> !     oText = DrawText(string, 0, 0, msBuildPath(szPath,
>>       if (oText)
>> +         SWFDisplayItem i;
>> !         i = SWFMovie_add(GetCurrentMovie(map, image), oText);
>> !         SWFDisplayItem_moveTo(i, x, y);
>> !       SWFDisplayItem_rotate(i, (float)label->angle);
>>       return 0;
>> *** 1997,2005 ****
>>           return(-1);
>> !     oFont  = loadSWFFontFromFile(fopen(msBuildPath(szPath,
>> fontset->filename, font), "rb"));
>>       if (oFont)
>>           //SWFText_addString(oText, string, NULL);
>> --- 2004,2014 ----
>>           return(-1);
>> !     FILE *f = fopen(msBuildPath(szPath, fontset->filename, font),
>> "rb");
>>       if (oFont)
>> +         fclose(f);
>> *** 2543,2548 ****
>> --- 2552,2558 ----
>>       int         nLength;
>>       int         iPointPos;
>>       int         iSlashPos;
>> +     int         iSaveResult;
>>       char        szAction[200];
>>       SWFAction   oAction;
>>       mapObj      *map = NULL;
>> *** 2558,2565 ****
>>                                                  "OUTPUT_MOVIE",""),
>>                          "MULTIPLE") != 0)
>> !             SWFMovie_save(image->img.swf->sMainMovie, filename);
>>               return(MS_SUCCESS);
>> --- 2568,2579 ----
>>                                                  "OUTPUT_MOVIE",""),
>>                          "MULTIPLE") != 0)
>> !         iSaveResult = SWFMovie_save(image->img.swf->sMainMovie,
>> filename);
>> !         if (!iSaveResult) {
>>               return(MS_SUCCESS);
>> +         }else{
>> +             return(MS_FAILURE);
>> Mapserver-dev mailing list
>> Mapserver-dev at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
> Assefa Yewondwossen           Software Analyst
> Email: assefa at dmsolutions.ca    http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
