[Mapserver-dev] Can't run PHP/Mapscript as a CLI????
Daniel Morissette
morissette at dmsolutions.ca
Wed Jun 11 14:05:09 EDT 2003
woodbri at swoodbridge.com wrote:
> Whoever is making this check needs to relax it so you can run as a
> CLI for debugging purposes.
I have added "cli" to the test in php_mapscript.c, so now the accepted
SAPI names are "cgi", "cgi-fcgi" and "cli".
(I did this in both CVS branches: 4.0 and 3.6)
> There may be other ways, but my standard
> way to debug server 500 errors and other problems is to run php like:
> [root at woodbri htdocs]# export
> QUERY_STRING='TEMPLATE=geobase_en.html&CONTEXT=geobase_regional_en.xml
> &sessionid=123455677'
> [root at woodbri htdocs]# export REQUEST_METHOD=GET
> [root at woodbri htdocs]# export REDIRECT_STATUS=200
> [root at woodbri htdocs]# php cwc2.php
> or run it in the debugger to see where it dies. This used to work
> fine.
You could simply call your php CGI for debugging with an explicit path,
that's what we always do.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
