[Mapserver-dev] Draw line with antialias
andrea.rogges at virgilio.it andrea.rogges at virgilio.it
Fri Jun 13 11:17:44 EDT 2003
It doesn't work :-(...I use a shapefile layer only with lines...the problem
can be in SYMBOL definition?
>-- Messaggio originale --
>Date: Fri, 13 Jun 2003 11:10:01 -0400
>From: Yewondwossen Assefa <assefa at dmsolutions.ca>
>To: andrea.rogges at virgilio.it
>CC: mapserver-dev <mapserver-dev at lists.gis.umn.edu>
>Subject: Re: [Mapserver-dev] Draw line with antialias
> From what I can see it the code you have to specify antilaias TRUE in
>the Style object :
> CALSS
>     Style
>        ANTIALIAS TRUE
>      END
>andrea.rogges at virgilio.it wrote:
>>Sorry for my previous message, taking order of dll's now it works ;-)
>>But the question now is: how can I draw line with antialias ?
>>>Date: Fri, 13 Jun 2003 09:27:05 -0400
>>>CC: mapserver-dev at lists.gis.umn.edu
>>>New binaries are at :
>>>http://www2.dmsolutions.ca/mapserver/dl/mapserver-4.0-dev-win32-php4.3.2.zip
>>>>Thanks very much ;-)
>>>>Andrea.
>>>>PS: where can I find new files ?
>>>>>Date: Thu, 12 Jun 2003 11:45:37 -0400
>>>>>To: Daniel Morissette <morissette at dmsolutions.ca>
>>>>>CC: andrea.rogges at virgilio.it, mapserver-dev at lists.gis.umn.edu
>>>>>I will add that to the makefiles and It will be available in the next
>>>>>binaries sometime this afternoon.
>>>>>Later,
>>>>>>>The results is this message:
>>>>>>>"loadStyle(): GD library error: Antialiasing support is not available.
>>>>>>>Get a newer version of GD!"
>>>>>>>What can I do? Do I need to recompile MapServer with GD v2.0.15 instead
>>>>>>>of v2.0.12?
>>>>>>I fixed this after the 4.0 beta for the Unix version.  For the Windows
>>>>>>version, a -DUSE_GD_ANTIALIAS compile flag will have to be added to
>>the
>>>>>>makefiles.
>>>>>Assefa Yewondwossen
>>>>>Software Analyst
>>>>>Email: assefa at dmsolutions.ca
>>>>>http://www.dmsolutions.ca/
>>>>>Phone: (613) 565-5056 (ext 14)
>>>>>Fax:   (613) 565-0925
>>>>_______________________________________________
>>>>Mapserver-dev mailing list
>>>>Mapserver-dev at lists.gis.umn.edu
>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
>>>Assefa Yewondwossen
>>>Software Analyst
>>>Fax:   (613) 565-0925
>Assefa Yewondwossen
>Software Analyst
>Fax:   (613) 565-0925
