[Mapserver-dev] Draw line with antialias
Steve Lime
steve.lime at dnr.state.mn.us
Fri Jun 13 12:10:18 EDT 2003
Since you're using an ellipse (a brush) the output cannot be antialiased
with GD as it sits now.
Steve
>>> <andrea.rogges at virgilio.it> 06/13/03 10:55AM >>>
Here is my mapfile definition...
>-- Messaggio originale --
>Date: Fri, 13 Jun 2003 10:50:42 -0500
>From: "Steve Lime" <steve.lime at dnr.state.mn.us>
>To: <assefa at dmsolutions.ca>,<andrea.rogges at virgilio.it>
>Cc: <mapserver-dev at lists.gis.umn.edu>
>Subject: Re: [Mapserver-dev] Draw line with antialias
>Send your mapfile definition. You can tell if it's working by the
time
>it takes to generate a
>map. Antialiasing is SLOOOOWWWW.
>There are also some caveats to the GD support- these are GD issues,
not
>MapServer issues.
>For example, styled symbols (i.e. dashes) cannot be antialiased, nor
>can brushed lines. Overall
>I was pretty disappointed with the support as it sits now. I'm sure
it
>will bet better over time.
>Steve
>>>> <andrea.rogges at virgilio.it> 06/13/03 10:17AM >>>
>It doesn't work :-(...I use a shapefile layer only with lines...the
>problem
>can be in SYMBOL definition?
>>Date: Fri, 13 Jun 2003 11:10:01 -0400
>>From: Yewondwossen Assefa <assefa at dmsolutions.ca>
>>To: andrea.rogges at virgilio.it
>>CC: mapserver-dev <mapserver-dev at lists.gis.umn.edu>
>> From what I can see it the code you have to specify antilaias TRUE
>in
>>the Style object :
>> CALSS
>> Style
>> ANTIALIAS TRUE
>> END
>>andrea.rogges at virgilio.it wrote:
>>>Sorry for my previous message, taking order of dll's now it works
>>>But the question now is: how can I draw line with antialias ?
>>>>Date: Fri, 13 Jun 2003 09:27:05 -0400
>>>>CC: mapserver-dev at lists.gis.umn.edu
>>>>New binaries are at :
>>>>http://www2.dmsolutions.ca/mapserver/dl/mapserver-4.0-dev-win32-php4.3.2.zip
>>>>>Thanks very much ;-)
>>>>>Andrea.
>>>>>PS: where can I find new files ?
>>>>>>Date: Thu, 12 Jun 2003 11:45:37 -0400
>>>>>>To: Daniel Morissette <morissette at dmsolutions.ca>
>>>>>>CC: andrea.rogges at virgilio.it, mapserver-dev at lists.gis.umn.edu
>>>>>>I will add that to the makefiles and It will be available in the
>next
>>>>>>binaries sometime this afternoon.
>>>>>>Later,
>>>>>>>>The results is this message:
>>>>>>>>"loadStyle(): GD library error: Antialiasing support is not
>available.
>>>>>>>>Get a newer version of GD!"
>>>>>>>>What can I do? Do I need to recompile MapServer with GD
v2.0.15
>instead
>>>>>>>>of v2.0.12?
>>>>>>>I fixed this after the 4.0 beta for the Unix version. For the
>Windows
>>>>>>>version, a -DUSE_GD_ANTIALIAS compile flag will have to be
added
>to
>>>the
>>>>>>>makefiles.
>>>>>>Assefa Yewondwossen
>>>>>>Software Analyst
>>>>>>Email: assefa at dmsolutions.ca
>>>>>>http://www.dmsolutions.ca/
>>>>>>Phone: (613) 565-5056 (ext 14)
>>>>>>Fax: (613) 565-0925
>>>>>_______________________________________________
>>>>>Mapserver-dev mailing list
>>>>>Mapserver-dev at lists.gis.umn.edu
>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
>>>>Assefa Yewondwossen
>>>>Software Analyst
>>>>Fax: (613) 565-0925
>>Assefa Yewondwossen
>>Software Analyst
>>Fax: (613) 565-0925
