[Mapserver-dev] Draw line with antialias
Steve Lime
steve.lime at dnr.state.mn.us
Fri Jun 13 13:51:41 EDT 2003
Based on the GD docs you may only draw single width lines antialiased.
So if you want
fat lines you have 1 option at the moment:
- draw a fat center with single pixel lines on the outside (styles
with offsets)
Ideally the CARTOLINE symbol type will be the way to go because is
creates a thick line
by creating a filled polygon and not a brush. So, in that case we could
add to that code
to draw an outline around the line polygon that could be antialiased. I
don't believe the
author of that code has mucked with GD antialiasing yet. I will mention
it to him though.
Steve
>>> <andrea.rogges at virgilio.it> 06/13/03 11:15AM >>>
OK, what is your suggest for obtain a line drawing with antialias?
>-- Messaggio originale --
>Date: Fri, 13 Jun 2003 11:10:18 -0500
>From: "Steve Lime" <steve.lime at dnr.state.mn.us>
>To: <assefa at dmsolutions.ca>,<andrea.rogges at virgilio.it>
>Cc: <mapserver-dev at lists.gis.umn.edu>
>Subject: Re: [Mapserver-dev] Draw line with antialias
>Since you're using an ellipse (a brush) the output cannot be
antialiased
>with GD as it sits now.
>Steve
>>>> <andrea.rogges at virgilio.it> 06/13/03 10:55AM >>>
>Here is my mapfile definition...
>>Date: Fri, 13 Jun 2003 10:50:42 -0500
>>Send your mapfile definition. You can tell if it's working by the
>time
>>it takes to generate a
>>map. Antialiasing is SLOOOOWWWW.
>>There are also some caveats to the GD support- these are GD issues,
>not
>>MapServer issues.
>>For example, styled symbols (i.e. dashes) cannot be antialiased, nor
>>can brushed lines. Overall
>>I was pretty disappointed with the support as it sits now. I'm sure
>it
>>will bet better over time.
>>Steve
>>>>> <andrea.rogges at virgilio.it> 06/13/03 10:17AM >>>
>>It doesn't work :-(...I use a shapefile layer only with lines...the
>>problem
>>can be in SYMBOL definition?
>>>Date: Fri, 13 Jun 2003 11:10:01 -0400
>>>From: Yewondwossen Assefa <assefa at dmsolutions.ca>
>>>To: andrea.rogges at virgilio.it
>>>CC: mapserver-dev <mapserver-dev at lists.gis.umn.edu>
>>> From what I can see it the code you have to specify antilaias TRUE
>>in
>>>the Style object :
>>> CALSS
>>> Style
>>> ANTIALIAS TRUE
>>> END
>>>andrea.rogges at virgilio.it wrote:
>>>>Sorry for my previous message, taking order of dll's now it works
>>>>But the question now is: how can I draw line with antialias ?
>>>>>Date: Fri, 13 Jun 2003 09:27:05 -0400
>>>>>CC: mapserver-dev at lists.gis.umn.edu
>>>>>New binaries are at :
>>>>>http://www2.dmsolutions.ca/mapserver/dl/mapserver-4.0-dev-win32-php4.3.2.zip
>>>>>>Thanks very much ;-)
>>>>>>Andrea.
>>>>>>PS: where can I find new files ?
>>>>>>>Date: Thu, 12 Jun 2003 11:45:37 -0400
>>>>>>>To: Daniel Morissette <morissette at dmsolutions.ca>
>>>>>>>CC: andrea.rogges at virgilio.it, mapserver-dev at lists.gis.umn.edu
>>>>>>>I will add that to the makefiles and It will be available in
the
>>next
>>>>>>>binaries sometime this afternoon.
>>>>>>>Later,
>>>>>>>>>The results is this message:
>>>>>>>>>"loadStyle(): GD library error: Antialiasing support is not
>>available.
>>>>>>>>>Get a newer version of GD!"
>>>>>>>>>What can I do? Do I need to recompile MapServer with GD
>v2.0.15
>>instead
>>>>>>>>>of v2.0.12?
>>>>>>>>I fixed this after the 4.0 beta for the Unix version. For the
>>Windows
>>>>>>>>version, a -DUSE_GD_ANTIALIAS compile flag will have to be
>added
>>to
>>>>the
>>>>>>>>makefiles.
>>>>>>>Assefa Yewondwossen
>>>>>>>Software Analyst
>>>>>>>Email: assefa at dmsolutions.ca
>>>>>>>http://www.dmsolutions.ca/
>>>>>>>Phone: (613) 565-5056 (ext 14)
>>>>>>>Fax: (613) 565-0925
>>>>>>_______________________________________________
>>>>>>Mapserver-dev mailing list
>>>>>>Mapserver-dev at lists.gis.umn.edu
>>>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
>>>>>Assefa Yewondwossen
>>>>>Software Analyst
>>>>>Fax: (613) 565-0925
>>>Assefa Yewondwossen
>>>Software Analyst
>>>Fax: (613) 565-0925
