[Mapserver-dev] Error Messages
Steve Lime
steve.lime at dnr.state.mn.us
Thu Jun 19 12:53:44 EDT 2003
I thought the PHP version could leverage the error stack that Dan added?
Also you can
set the MS_ERROR environment variable and all errors will be echoed to
the file named
in the env variable. There probably is a meaningful error message being
generated but
it's being overridden by a more generic one. I know that's the case in
the msDraw...
function.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Dylan Keon <keon at nacse.org> 06/19/03 02:31AM >>>
woodbri at swoodbridge.com wrote:
> This is very frustrating. I pointed the symbolset to another working
> symbolset file in it worked great, but I still haven't a clue why
> this other file does not work, or what line is a problem, or
> anything. In fact I commented out 99% of the file and it still had
> problems so I not even sure if it can access the file or it is
> something in the file. A core file would be more useful!
Steve,
IIRC, I had the same problem a few months ago. I think I discovered
that images listed in the symbols file need to have absolute paths. It
must have been when I switched to 3.7, because prior to that relative
paths worked fine for me.
--Dylan
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
