[Mapserver-dev] RE: postgis db connection caching...
Paul Ramsey
pramsey at refractions.net
Sat Jun 21 18:09:31 EDT 2003
Given thought to and implemented.
Jan Hartmann committed a per-session caching scheme about 6 months
ago. Layers which use the same connection can pull the handle from a
connection pool.
Read through the SDE layer to see it in action. Currently it is only
used by the SDE layer type. We may add it to the PostGIS section, but
frankly connection overhead is very small for PgSQL.
As far as mapscript goes, the idea system would be one where handles
could be passed into mapscript from an external application. But that
could be really hard to do in a way which binds nicely with multiple
languages.
Paul
Chris G. Nicholas wrote:
> Before I attempt shameless experimental hacking, has anyone given
> thought to caching db connections, both within the same mapfile
> across different layers, and in general within mapscript
> applications?
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
