[Mapserver-dev] compiling on Mac OS/X 10
mapsurfer
mapsurf at midsouth.rr.com
Wed May 7 06:17:35 EDT 2003
Guys, I spent a few hours debugging an install on Mac OS/X... An older
mapserver version kept crapping on itself with this error:
> ld: Undefined symbols:
> ___gxx_personality_v0
After a bit of research, I finally found the fix:
In configure.in, just below the libm check, I added the following library
check:
AC_CHECK_LIB(stdc++,__gxx_personality_v0, XTRALIBS="$XTRALIBS -lstdc++",,)
AC_SUBST(XTRALIBS, $XTRALIBS)
LIBS="$XTRALIBS $LIBS"
re-ran autoconf, and all is well. The Mac OS/X is very BSD'ish, but Apple
has alot of
wierdness to it. It is quite possible this could be added to the standard
distributed without
ill effects, and would make it a bit more portable (ie. it couldnt hurt).
Regards,
Chris Stuber (mapsurfer)
Silicon Mapping Solutions, Inc.
